Thread: Climatronic Diagnostics
Hybrid View
  1. Climatronic Diagnostics
    Aug 2007
    I've recently discovered the Diagnostics mode on my Climatronic control panel and I was wondering if anyone had a list of what the diags were as there are loads available?
    ECON / Fan Down / Temp Down button activates it before anyone asks...
    milenia
  2. Re: Climatronic Diagnostics
    A, A
    Climatronic Information
    1. Press Fan Down, Temperature Colder (blue), ECON at the same time.
    2. Use the temperature control buttons to cycle through the various channels to Channel 16.
    3. Press ECON to go back to normal. (It goes back automatically when you restart the car.)
    Translated as:
    Contents of 1 system error # system error
    2 actual value feeler virtually # actual VALUE sensor virtual
    3 actual value of interior feelers console # actual VALUE internal sensor CONSOLE
    4 actual value outside temperature feeler wasserkasten # actual VALUE outside temp sensor water reservoir
    5 actual value outside temperature feeler bumper # actual VALUE outside temp sensor more bumper
    6 actual value blowing out feeler floor space # actual VALUE bloweroutlet sensor footspace
    7 actual value blowing out feeler Mannanstroemer # actual VALUE bloweroutlet sensor dashboard
    8 display CHECKS #
    9 actual digital value answering potentiometer temperature flap # actual digitally VALUE feedback potentiometer temp valve
    10 debit digital value temperature flap # set digitally VALUE temp valve
    11 actual digital value answering potentiometer A/C flap
    12 debit digital value A/C flap
    13 actual digital value answering potentiometer Fuss/Def. Flap
    14 debit digital value Fuss/Def. Flap
    15 actual digital value answering potentiometer ram air flap
    16 debit digital value ram air flap
    17 driving speed (km/h) 16
    18 actual value of the blower voltage (volt) 19 desired value of the blower voltage (volt)
    20 actual value of the compressor/on-board voltage (volt)
    21 amount of of low-voltage events (not volatile)
    22 switching status of the high pressure feeler
    23 number of high pressure events (volatile)
    24 number of high pressure events (not volatile)
    25 A/D value kickdown switch
    26 A/D value hot light
    27 engine speed
    28 compressor number of revolutions
    29 coding
    30 software-Version
    31 software index of
    32 potentiometer error counters temperature flap of
    33 potentiometer error counters A/C flap of
    34 potentiometer error counters Fuss/def. Flap of
    35 potentiometer error counters ram air flap
    36 temperature flap impact coldly
    37 temperature flap impact warmly
    38 A/C flap impact closed
    39 A/C flap impact openly
    40 Fuss/Def. Impact Def folds.
    41 Fuss/Def. Impact foot
    42 ram air flap impact on
    43 ram air flap impact folds to
    44 operating cycle counters
    45 interior temperature counted (Nine) dig
    46 outside temperature filtered °C
    47 outside temperature not filtered °C
    48 ECOR of
    49 error counters Tachosignal
    50 service life in min
    51 engine temperature °C
    52 compressor power-off conditions (appendix)
    53 display more actively el. Outputs x x compressor circulating air valve x water valve
    54 rule code digit
    55 outside temperature °C of
    56 interior feelers virtually °C of
    57 interior feelers console °C
    58 temperature wasserkasten °C
    59 temperature bumper °C of
    60 blowing out feelers floor space °C of
    61 blowing out feelers Mannanstroemer °C
    62 sun intensity W/m² 3
    63 sun intensity filtered W/m²
    64 delta exhaust rise
    65 delta A/C flap shift
    66 time constant 1.8 seconds of
    67 cold weather starting correction
    68 max. correcting variable for i or sectionsection section of
    69 actual value blowing out feeler foot (cnts)
    70 desired value blowing out feeler foot (cnts)
    71 deviation (Epsilon)
    72 proportion (+heizen - cool)
    Just another B7 Estate
  3. Re: Climatronic Diagnostics
    Aug 2007
    The list you provided doesn't tie up, only has 60 something items. Does anyone else have a list of the Diags?
    Also found other features / options.
    Is there a list showing every option available on the Climatronic Display?
    milenia
  1. Vag Com or any other Diagnostics
    By Muddy19 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-08-2008, 11:29 PM
  2. Audi Diagnostics
    By abbeyhouse in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-10-2007, 04:03 PM
  3. thoughts on this diy handheld diagnostics
    By stubbsy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-07-2007, 03:51 PM
  4. Passat Diagnostics
    By derekdublin in forum Passat - Archive Topics
    Last Post: 13-02-2007, 12:25 AM
  5. Which VAG COM Cable To Purchase For Diagnostics?
    By Studio54 in forum Passat - Archive Topics
    Last Post: 12-10-2006, 06:17 PM
