Thread: Fault code 18072
  1. Fault code 18072
    Southern County Softy
    20 Post(s)
    Hi All
    Daughter's A3 is nor playing ball.
    It has recently had an ECU replaced due to water ingress.
    Car has run fine for a couple of weeks.
    Last 2 days the engine is cutting out and throwing the code 18072.
    Can't find this code on the wiki, had search round and found nothibg definitive.
    Could this be a faulty loom ?
    Sent from my GT-I9305 using Tapatalk
    A4 2.5 tdi QS (mapped)
  2. Re: Fault code 18072
    46 Post(s)
    Error 18072 ------- Intermittent
    Steve seems to think its wiring related.
    18072 (P1664) Unit injector solenoid valve activation. Electrical fault in current circuit.
    Open circuit in wiring or short circuit to earth in engine wiring harness
    That looks like a problem with the injector power supply from the ECU on the brown/yellow wire.
    Not filling the fuel filter just means it takes longer to get going as yours does not have a lift pump in the tank but the O rings on the plastic connector could be the problem.
  3. Re: Fault code 18072
    20 Post(s)
    Yeah seen that. The car is 10 years old now and has run faultless.
    I slso suspect the injector loom.
    Will talk to the guy that dibe the ECU tomorrow.
  1. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  2. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  3. Error 18072 ------- Intermittent
    By macarthur.2000 in forum VCDS - Help Requests
    Last Post: 13-01-2010, 12:34 AM
  4. Error 18072 - Intermitant!!!!!!!
    By macarthur.2000 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-01-2010, 06:37 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
