Thread: Audi A6 C6 Driver Heated Seat Issue
  1. Audi A6 C6 Driver Heated Seat Issue
    Jan 2014
    Nottingham
    Hi everyone
    I have an annoying issue with my audi a6 driver heated seat does not work at all, checked error code comes up with 'open circuit' Any ideas?IMG-20140122-WA0012.jpg
    Audi A6 2.7TDI Quattro
  2. Re: Audi A6 C6 Driver Heated Seat Issue
    Nov 2012
    Somerset UK
    If you have VCDS and it's giving you a fault reference you can simply google it.
    Appreciate that a heated seat is just an element and has wires running to it, so it's fair to say that there's either a disruption to the power either in the wiring or the seat element itself. Have you had a look under your seat and cleaned the connections as a first port of call?
  3. Re: Audi A6 C6 Driver Heated Seat Issue
    Jan 2014
    Nottingham
    Yes I shall do that thanks for the obvious tip, I just hope its not the element inside the seat, if it is any ideas on how to repair this.
    Iv really had bad luick with heated seats every car iv had the driver side heated seat does not work!!
    Audi A6 2.7TDi Sline quattro auto
  4. Re: Audi A6 C6 Driver Heated Seat Issue
    Nov 2012
    Somerset UK
    Probs previous owner has had a fat or a pointy @rse!
    The actual heated seat elements are cheap to buy, however I've only had to add them when doing a retrim, so simply asked the trimmer to do so.
    The problem I see is getting one that matches the audi 6 settings (well it has that in my case)
    You need to explain your problem a little better.
    1) Is the passenger side one working fine?
    2) Is the light on the button staying on?
    3) If yes to 2 then can you move the temp up and down 1-6?
    As you'll know you have to look at the lowest cost fixes first, so I'd say those were:
    a) Checking and cleaning the contacts
    b) identifying the heated seat wires and checking with a voltmeter that current is reaching the seat
    If yes to b then it's most likely the element and a rather tricky/expensive job, at that time you'll need to price a replacement from Audi, as a guide there are Audi ones on Ebay but not for the A6, for example this one:
    NEW GENUINE AUDI A3 8P FRONT HEATED SEAT BASE ELEMENT - 8P0 963 555 E | eBay
    All of my advice common sense stuff to most
  5. Re: Audi A6 C6 Driver Heated Seat Issue
    Jan 2014
    Nottingham
    Passenger works fine
    Lights are on
    Heater level moves up and down (1-6)
    Thanks for your help dude!
  6. Re: Audi A6 C6 Driver Heated Seat Issue
    Nov 2009
    46 Post(s)
    Come on, give us the code!
  1. A6 Seat Swap - Heated Seat Question
    By flippantaudi in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-11-2013, 05:05 PM
  2. Please Help What is this? A nice cute button near the driver seat. At the seat belt position
    By han95 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-07-2013, 06:57 PM
  3. Driver side - Electric heated seat doesn't work!
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-09-2010, 12:27 PM
  4. Driver heated seat
    By mickwillow in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-05-2010, 09:49 PM
  5. Heated seat issue
    By j man in forum Archive posts
    Last Post: 11-11-2006, 08:05 PM
