Thread: EGR Duty Cycle stuck on 99.6 %
  1. EGR Duty Cycle stuck on 99.6 %
    Jan 2014
    United Kingdom
    Hi all,
    I have a 3.0TDi A6 (2010) CDY engine code and am getting pretty low MPG figures. I ran a VCDS log of Group 003 on my last trip to work and noticed that there constantly seems to be around a 200 mg/str difference between the 'actual' and 'specified' MAF values - 'actual' being consistently higher. In addition, the EGR Duty Cycle does not change from 99.6%.
    No fault codes showing in VCDS.
    Any ideas on other tests I can perform? Thinking something not right with these readings.
    Thank you.
  2. Re: EGR Duty Cycle stuck on 99.6 %
    46 Post(s)
    how "low" is low mpg?
  3. Re: EGR Duty Cycle stuck on 99.6 %
    Jan 2014
    United Kingdom
    Hi A6_Chris,
    I have read quite a few posts about MPG on the 3.0TDi engines and appreciate that I did not pick this engine for economy :-). I seem to get 16-18 MPG on my daily commute - admittedly it is a 7 mile commute and I do sometimes have traffic. Yet, even on longer, clear runs on dual carriage way, I am not seeing above 27 MPG on the average for that drive.
    Audi list this engine (2010 model) as 30.4 MPG Urban, Average 39.8 MPG. I dream of getting near those figures....
    The car has covered 67K miles, so possibly something needs a clean/replacing.
    I unplugged the MAF for a test one night and drove home. This did not seem to alter my MPG figures showing on the dash. Would be grateful of any additional tests/checks people can recommend.
    Thanks,
  4. Re: EGR Duty Cycle stuck on 99.6 %
    Nov 2012
    Somerset UK
    Yikes!! I get 26-30 dropping my kids to school an it's less than 1.5 miles round trip on a cold engine
  5. Re: EGR Duty Cycle stuck on 99.6 %
    Jan 2014
    United Kingdom
    Hi MarkTM, I see you feel my pain
    Had a slight development....I played with the VCDS output tests on my engine today - all seemed to do something and I had fun tracing all the buzzing and other noises around the engine bay - and I think it may have slightly freed a sticking component or it may just be a coincidence.
    Driving home tonight, I had an average of 24MPG and the EGR valve duty cycle was changing slightly. It went down to about 50% for one reading but most readings were between 80.0 - 99.6%. It seems to keep drifting up to 99.6% and when at this value the 'Actual' and 'Specified' MAF readings start to differ by up to 200 mg/str.
    Any ideas?
    Thanks,
  6. Re: EGR Duty Cycle stuck on 99.6 %
    Apr 2013
    Bradford, England
    I think my 2.0 has a similar issue. Really low MPG and a slight misfire at idle. Think i might strip down EGR Valve and clean it when I get a bit of free time
    2015 Audi A6 2.0 TDi Ultra Black Edition Saloon - Ibis White - Lunar Silver - S-Line Sports Suspension - RS6 Wheels
  7. Re: EGR Duty Cycle stuck on 99.6 %
    Jan 2014
    United Kingdom
    Hi all,
    I have done a few more logs while driving and have noticed the following:
    MVB 10.1 (Actual MAF): From what I can see (courtesy of other posts on here) this should range between 210mg/stroke at idle to greater than 1050mg/stroke at full throttle. I am seeing a lowest value of 250mg/stroke (287 at idle) and a maximum value of 1122mg/stroke, which is within range but seems a little high at idle.
    Is anyone able to check if my engine (CDY) has different ranges for this value? Or provide a list of measuring blocks for my engine?
    Any other ideas which parameters I should be checking?
    I have fitted a new Lambda sensor as some readings from this seemed strange but no change. I have also removed and cleaned the MAF. I was going to remove the throttle body adapter to clean it but was stopped in my tracks as my engine does not have a separate adapter, it is a single cast piece from the throttle body to the intake manifold and I can't work out how to remove it without unbolting fuel lines.
    Thanks,
  1. Heavy duty rear suspension
    By shuvit2 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-02-2014, 11:19 AM
  2. Can't change service interval or EGR duty cycle on 2004 A4 2.5 tdi
    By digger42 in forum VCDS - General Questions
    Last Post: 28-08-2011, 09:43 PM
  3. Question New Heavy Duty Battery
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-02-2011, 04:50 PM
  4. Call of Duty 5
    By onemanparty in forum Chat - Completely Off Topic
    Last Post: 19-01-2009, 05:37 PM
  5. Fuel duty petition.
    By boofont in forum Chat - Completely Off Topic
    Last Post: 11-08-2008, 10:42 PM
