Thread: Rev needle bounce
  1. Rev needle bounce
    Dec 2007
    Belfast
    Hi All.
    Got the car back from the mechanic yesterday after getting the drivers seat bracket welded, and today she is giving me problems.
    When the car is started, from cold or warm, the rev needle is doing some serious bouncing, anything between 700rpm to 1100rpm.
    She doesn't cut out or anything, but it is bloody annoying.
    I am thinking along the lines of throttle body or ignition coil loom ?
    Can someone point me in the right direction please.
    Thanks.
    Belfastmark.
  2. Re: Rev needle bounce
    Dec 2007
    Belfast
    Just to udpdate, took her to the workshop to have a wee look.
    No fault codes showing with a sealey diagnostic machine, ( Don't have VAGCOM )
    Engine cover off, doesn't seem to be any split hoses or loose connections, as far as I am concerned, everything looks fine.
    Just to add, when the seat bracket was being replaced, the battery was dis-connected for a period of time, could this be relevant ?
  3. Re: Rev needle bounce
    Aug 2011
    Meath
    You probably need the throttle body aligned mate sometimes can happen when power is lost
  4. Re: Rev needle bounce
    Dec 2007
    Belfast
    Thanks for the reply Doctle.
    I don't know of anyone who has the software to align the throttle body. It would have to be a VW job. Was wondering if after a while, could the car recognize and re learn the values of the throttle body ? Could it be taken out,cleaned and put back in carefully with out software ?
  5. Re: Rev needle bounce
    Aug 2011
    Meath
    Plenty of guys with VCDS near Belfast Mark including A6_Chris. Any of them will align your throttle if that's the problem. Throttle bodies are a bit like people they never learn by themselves, look here VWAF User Location Map - VCDS - Google Maps
  1. Please Help belt? squeal/squeek + rev counter needle bounce.
    By geejayy in forum Golf MK3 - 1993 - 1999
    Last Post: 10-06-2013, 06:19 PM
  2. Rev needle bounce
    By belfastmark in forum Golf MK4 - 1999 - 2004
    Last Post: 07-03-2012, 02:37 PM
  3. rev counter needle not working as it should
    By wilki in forum Polo - Derby - Lupo - Fox
    Last Post: 31-12-2010, 04:17 PM
  4. how do i remove my rev counter needle
    By domo gaz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-12-2010, 03:24 PM
  5. Rev Counter needle SDI ,
    Last Post: 13-11-2010, 11:46 AM
