Thread: ESP, ABS and power streering lights on - how to fix it?
Results 1 to 10 of 10
  1. Question ESP, ABS and power streering lights on - how to fix it?
    May 2011
    Hello,
    Some time ago, ESP and ABS lights started coming on randomly and sometimes at around 75mph. I was ignoring it, but I need to fix it now.
    The other day i had to disconnect the battery, and when I connected it back the ABS light doesn't come on, but the ESP and the power steering lights are on now.
    All lights mean some kind of malfunction.
    Is this something I need to be worried about or is it just a computer glitch and needs resetting? If so, what is the best diagnostic tool I can get on ebay to fiddle with A3 8P 2006?
    Thanks in advance!
  2. Re: ESP, ABS and power streering lights on - how to fix it?
    Pembrokeshire
    22 Post(s)
    this 2013 LAUNCH CREADER CRP123 PRO DIAGNOSTIC SCANNER USA ASAIN EURO CARS 1996-2013 | eBay
    is a good piece of kit. most of the cheaper ones are only any good for obd faults, you need a more specific machine. personally, if you only want to use it on your a3 i would get vcds, or find someone local with it who can read your codes. there is a map with locations on of members willing to help.
  3. Re: ESP, ABS and power streering lights on - how to fix it?
    May 2011
    Are you saying this is a glitch that requires resetting only? Wont a £5 VCDS cable do the job?
    Thanks for the map I did look there. Should I just send a PM to someone who's near me?
  4. Re: ESP, ABS and power streering lights on - how to fix it?
    Sep 2008
    Good God! £5K for a scanner!
  5. Re: ESP, ABS and power streering lights on - how to fix it?
    Pembrokeshire
    22 Post(s)
    thats cheap. my snapon modis would set you back 7. the autologic set up will cost more, then 10k per cartridge for each make of car. but thats as good as they come and will do more than any computer. this is why us traders get a bit narked when people moan about paying for a scan or claim their 30 quid ebay scanner is dealer level.
  6. Re: ESP, ABS and power streering lights on - how to fix it?
    Sep 2008
    Actually, I just looked at the sales history as selling over 100 of those seemed a lot. There has been an accidental "5" added at the beginning of the price, so they are about £150........
  7. Re: ESP, ABS and power streering lights on - how to fix it?
    May 2011
    Hm... the lights went away today and I haven't even done anything. They will probably come up again...
  8. Re: ESP, ABS and power streering lights on - how to fix it?
    Jan 2011
    East Kent
    What I think has happened is that you've had the battery disconnected for a while and this has cleared the ABS fault - hence why the ABS light has now gone out...and this is also the reason why the ESP and power steering light has come on. It is normal for the ESP and power steering light to come on after the battery has been disconnected for a while and they go out after you've driven a short distance.
    But you are correct, if the fault returns then so will the ABS light.
    Previous: 2005 A3 1.9tdi SE
    2009 Audi A3 2.0tdi 138bhp SE
  9. Re: ESP, ABS and power streering lights on - how to fix it?
    May 2011
    Are there any common causes for this? or do you reckon it's just a ecu glitch?
  10. Re: ESP, ABS and power streering lights on - how to fix it?
    Jan 2011
    East Kent
    I believe that this is a common problem. Search for ABS on this page: http://www.honestjohn.co.uk/carbycar.../?section=good (and even on the similar VW Golf Mk V page). In particular note the comment regarding the fuse. Given the circumstances etc. you have described in your first post, this does seem plausible as you clearly have an intermittent issue going on. I know of someone myself that had an ABS fault with their Fabia. The garage replaced the ABS control unit to then discover it was the fuse.
  1. ABS and ESP lights on
    By 3george in forum Golf MK5 - 2004 - 2009
    Last Post: 01-02-2014, 11:07 PM
  2. Please Help A3 ABS and ESP lights
    By ford776 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-05-2012, 04:57 PM
  3. Replies: 13
    Last Post: 15-12-2011, 08:58 AM
  4. V5 with no ABS/ESP lights?
    By RichGee in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2011, 07:37 PM
  5. Power streering squeak
    By 8ball in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-04-2009, 09:08 AM
