Thread: Handbrake
Results 1 to 10 of 11
  1. Handbrake
    Jan 2014
    Donny
    Hi guys,
    Had my 1.9tdi two weeks now and loving it but found the handbrake really isn't great. The car creaks and is easily rolled with minimal effort. Is this a common fault and how much a I looking a to get repaired/replaced?
    Many thanks!
    Jon
  2. Re: Handbrake
    Pembrokeshire
    22 Post(s)
    no, not a common fault. yours has a problem and needs fixing. cost depends what is wrong. could be worn pads and/or discs, pads siezed in caliper, caliper slide bolts stuck, or cables no good, or calipers siezed. so worst case is new pads, discs, carriers, calipers and cables, which will be loads, best is and hours worth of labour to clean it all up and unsieze some stuck pads.
    0 2 0
  3. Re: Handbrake
    Sep 2008
    6 Post(s)
    Agree with zollaf. What I would do is to renew the rear piston seals. Audi do a kit which includes rubber dust sleeve and new caliper 'o' ring. You'll need a brake wind back tool. I'd also the lube cylinder bore with Lockheed red grease and the slide pins. Bleed brakes on completion (good opportunity to renew the fluid) which should be done every 2 years.
    The handbrake does stretch over time and the ends are known to fray. Check condition as a matter of course and replace where necessary. A full dismantle and rebuild works wonders.
    2016 BMW i3 REx (80k)
  4. Re: Handbrake
    Jan 2014
    Donny
    Just checked rear pads and both sides are very worn opposed to the fronts. Could this be the problem?
  5. Re: Handbrake
    Pembrokeshire
    22 Post(s)
    no, the pads and handbrake self adjust to compensate for wear. it could however be pointing to another problem , maybe something i mentioned earlier. your only option is to strip it down and see whats what, but if the pads are worn, replace them.
  6. Re: Handbrake
    Dec 2009
    southampton uk
    The back pads don't wear quickly.Do you know when they were last changed?I agree that theres likely to be a problem with the calipers which could be sticking.A careful check after use can tell if they seem to be too hot
  7. Re: Handbrake
    Jan 2014
    Donny
    No idea when they were last changed and there's no grinding, smell and heat coming off them after a drive?
  8. Re: Handbrake
    Dec 2009
    southampton uk
    So they are probably sticking off and you need to investigate why.If they are not warm after a drive it doesn't seem that you have much rear braking of any kind.When was the MOT?
  9. Re: Handbrake
    Jan 2014
    Donny
    Its due in April
  10. Re: Handbrake
    Dec 2009
    southampton uk
    That's long enough for it to have seized since last one
  1. Handbrake
    By broncoupe in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 26-03-2013, 06:05 AM
  2. Question handbrake
    By acano in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-11-2010, 08:32 PM
  3. Handbrake
    By caritajayne in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 27-07-2009, 12:15 PM
  4. handbrake
    By c viles in forum Golf MK4 - 1999 - 2004
    Last Post: 23-08-2008, 09:45 PM
  5. A6 handbrake
    By alogbe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-05-2008, 11:16 AM
