Thread: How do I "safely" increase my boost?
Results 1 to 10 of 14
  1. How do I "safely" increase my boost?
    Aug 2007
    okay, so I want to up the boost on my Transporter 2.5 TDi but I'm not sure how to do it safely, this is why.
    My system has a boost ref pipe that feeds the ECU, I've "T" into this just before the ECU to run pipe for my boost gauge. I think this has effected the control by placing a small reservoir in the small diameter pipework which is creating a delayed reaction type scenario. If I plant the throttle at around 2,000rpm I can sometimes get a boost spike of 1bar shown on the gauge. I'm not sure if this was there before but I suspect not.
    So First problem is my accidental boost spike.
    Next is the ECU sets the boost at 0.8 for 2,000rpm and reduces to 0.6 as it reaches 3,000rpm and up.
    So if I use a bleed valve and set it to give 1bar at high revs then I may get 1.2bar at low revs and 1.4 bar spike.
    What I really want if possible is about 1 bar across the rev range.
    Manual Boost Controller? - I'm not sure how an MBC would integrate with my system, as the waste gate is pressure controlled I guess it would have to bleed off the pressure applied to the wastegate - this would work for about 30 seconds by which time the ECU would have tripped into limp mode.
    So I sort of need a MBC and a boost ref bleed valve. It all sound like it's going to be an absolute pig to balance but maybe possible?
    So is there any sensible way of doing this without a remap?
    Rich.
  2. Re: How do I "safely" increase my boost?
    7 Post(s)
    Boost spikes are quite normal, I wouldn't worry about it.
    As for trying to up the boost without a corresponding increase in fuelling, I think you could easily end up damaging the engine.
    From what you have described, it sounds like it is behaving normally, i.e. the boost diminishes as the revs increase. A good test is to hoof it up a long fast motorway hill, the boost should hold at 1 bar all the way up.
    If you want t make it go quicker, get a remap done.
  3. Re: How do I "safely" increase my boost?
    Aug 2007
    Quote Originally Posted by BigCol View Post
    I'm glad you mentioned this as it's something I've never understood the need for, allow me to explain...
    Firstly it's a diesel, they really don't mind running lean, in fact they do normally and also run a lot cleaner/smoke free like this. The only consequence on not increasing the fuelling would be very little power gain.
    Also, the fuelling is electronically controlled and regulated via the MAF so if you increase the boost and control the heat you'll get a greater flow. The ECU will apply the appropriate amount of extra fuel to correspond to this increase unless you've already exceeded it's capacity (bigger injectors needed).
    I'm also running a tuning box which allows me to have some extra control on the fuelling but not the fuel timing which is where a remap may have an advantage.
    Yes, I think it is behaving normally and for some reason VW have decided to tail the boost off as the revs climb. The turbo (KKK K14) is a little underspec'ed for a 2.5 but the rev range isn't that high, plus others have managed to achieve more from this turbo so I wanted to give it a go without having to resort to a remap.
    Oh and it will never hold 1 bar in current set up, 0.8 is the max continuous boost and only at around 2,200 rpm. I have no idea why VW have mapped it to tail off as the revs climb, I've read that this prevents detonation but detonation is only something that effects petrol engines I believe.
  4. Re: How do I "safely" increase my boost?
    7 Post(s)
    I don't quite agree with what you are saying about the ecu correspondlingly increasing the fuelling to match the increased boost.
    Reason being, in simple terms a diesel engines speed is directly related to the amount of fuel going in, the boost control is secondary.
    What will happen if you increase the boost without the fuelling is that the ECU will sense a fault and throw itself into limp mode.
    To do it properly a remap is the way to go, a good map will optimise fuelling, boost and timing.
    However...
    I'd be really interested to know how you get on with this.
  5. Re: How do I "safely" increase my boost?
    Aug 2007
    Yes, the engine speed is controlled by the fuel going in, as is the case with any engine. What I am assuming in this case is "on throttle " condition. The ECU should be trying to produce as much power as it can so will be looking to allow full boost and supply 100% of permitted fuel for the given revs etc.
    It has a simple map which determines fuel delivery according to air mass and fuel temperature and throttle position.
    Is that correct?
    It can also adjust the timing as well I think, and may even alter the fuelling according the the actual engine rpm. I'm not sure of the full in's and out's of it.
    So the point is that if you increase the boost without letting the ECU know about it then it shouldn't trip into limp mode. Also as long as the air flow does go off the map (off scale) there should be no problem. The ECU will just sense that you have slightly higher than expected air flow and increase the fuel delivery to match. Much the same as the power increase you get with cold air.
    That is if this is how it works, if not then I can forget it.
    When I installed my intercooler there was definite increase in med to high speed power. This would not be the case unless the the ECU had automatically increased the fuel to take advantage of the increased quantity of air now entering the engine.
    So that's my plan, step the boost up and hope the ECU will compensate. If is doesn't do enough then I can help it a little more with my tuning box.
    So is the ECU clever enough to notice that the air mass no longer falls within the expected range and if so will it go into limp mode?
    Will the ECU simply disregard any extra air quantity over a certain level as the standard map doesn't go that high?
    These questions are what I'm hoping somebody can answer.
    As well as telling exactly how to implement this
    Cheers.
  6. Re: How do I "safely" increase my boost?
    7 Post(s)
    Quote Originally Posted by DubDick View Post
    I'd say it will reduce boost if it doesn't go into limp mode. The MAP sensor would see to that. So you'd be back to square one.
    Cheers.
    I wouldn't think so. Look at the Chip and Spin group buy on here, not that much money if you are pwoer hungry.
