Thread: Intermitten Alarm issue and Remote Lock/Unlock
Results 1 to 10 of 11
  1. Intermitten Alarm issue and Remote Lock/Unlock
    Jan 2014
    slough, UK
    I have a Audi A4 1.9 TDI, 2002 registration. It has developed a strange problem of setting alarm off intermittently even when I am driving.
    My remote locking does not work either, I have to open it manually and I need to put the key to ignition before its unlocked the whole car, If I don't put the key to ignition, alarm will set off.
    I have tried changing battery to the key fobs, reprogram keys etc. spoke to a electrician, he wanted to additional remote lock/unlock device as a workaround as oppose to addressing the min issue here. I wonder how that's going to affect exiting alarm systems.
    Any one had similar experience?
    Murad
  2. Re: Intermitten Alarm issue and Remote Lock/Unlock
    Southern County Softy
    20 Post(s)
    Check your front footwells for damp.
    Get the car scanned for faults.
    Sent from my GT-I9305 using Tapatalk
    A4 2.5 tdi QS (mapped)
  3. Re: Intermitten Alarm issue and Remote Lock/Unlock
    Jan 2014
    slough, UK
    Quote Originally Posted by kite View Post
    No damp, no fault found when scanned.
  4. Re: Intermitten Alarm issue and Remote Lock/Unlock
    131 Post(s)
    1976 Post(s)
    What type of aftermarket alarm is fitted?
  5. Re: Intermitten Alarm issue and Remote Lock/Unlock
    Jan 2014
    slough, UK
    I have not fitted any. it came with standard audi alarm
  6. Re: Intermitten Alarm issue and Remote Lock/Unlock
    20 Post(s)
    Does the drivers door show open on the dash ?
  7. Re: Intermitten Alarm issue and Remote Lock/Unlock
    Jan 2014
    slough, UK
    yes. dash board does not report any problem while the alarm goes off.
  8. Re: Intermitten Alarm issue and Remote Lock/Unlock
    131 Post(s)
    1976 Post(s)
    Quote Originally Posted by muradhakim View Post
    Ohh, sorry I presumed as you had posted it in "Vehicle-Security-Retrofit-aftermarket-alarms-amd-immobilisers" that is what it had....silly me!
    You need to look at the last trigger identification number. When it goes off, do the indicators flash?
  9. Re: Intermitten Alarm issue and Remote Lock/Unlock
    20 Post(s)
    Scan the car with VCDS.
    Autopool in Iver are good with Audi's.
  10. Re: Intermitten Alarm issue and Remote Lock/Unlock
    Jan 2014
    slough, UK
    yes indicator flashes. even the light in the boot also flashes (not sure why)
    The frequency of the indicator are not the same. Frequency gets higher of the indictor lights, often alarm goes off sometimes, sometimes its the indicator, sometimes both, this all happens while I am driving in a normal speed. if I indicate left or right, hazard lights stops.
    If I go to Audi They will charge me 96 pound +vat to find out what the problem is.
  1. Please Help Intermittent remote boot lock/unlock
    By craigdk in forum Bora - 1998 - 2005
    Last Post: 23-12-2012, 08:53 PM
  2. Question Remote boot lock/unlock
    By Alfonzo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-12-2012, 05:01 PM
  3. No alarm sound or lock/unlock chirp
    By cobology in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-09-2011, 10:01 PM
  4. Please Help 2 Issues - Car Door Lock problem & Car Alarm/Luggage Compartment Issue
    By jakeevans in forum Golf MK4 - 1999 - 2004
    Last Post: 05-09-2011, 08:18 PM
  5. Question Remote Central Locking does not lock/unlock drivers door
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-05-2011, 09:25 AM
