Thread: Oil pressure gague connection
  1. Oil pressure gague connection
    Aug 2008
    Chelmsford England
    My audi A4 1998 1.8 petrol sometimes has a rattle for a few seconds on start up when hot, but is otherwise quiet.
    This has been diagnosed by a Local Audi mechanic as the cam chain tensioner which is a bit worn at 150,000 miles - I have had the car for 7 years and the last 70,000 miles.
    I think the oil pressure is OK - ie the filter in the sump is probably not clogged - I believe that this problem usually only happens due to sludge formed by a hot turbuo which I do not have - also the oil has always been changed for the correct stuff at the right intervals since the car was new. The oil pressure light does not come on at any time when the engine is running.
    Before I change the cam chain tensioner however, I would like to check the oil pressure and have been unable so far to find where to connect a pressure gague. I gather it is somewhere near the oil filter but can not see where.
    Can anybody tell me how to find the connection to the oil gallery please.
    Matty
  2. Re: Oil pressure gague connection
    Colchester,Essex
    Near or on the filter housing should be an oil pressure switch.I never worked on 1.8 though but usually that is the location.
  1. Question Oil Pressure Warning Light - assumed oil pump fault. Advice and expected cost.?
    By dijjital in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-03-2017, 07:37 PM
  2. Oil Pressure Light on and oil temp not rising 02 AWX 1.9tdi
    By tone35 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-11-2012, 10:10 AM
  3. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
  4. Please Help my 1st vw caravelle (1995) fuel gague issue
    By GavinGD in forum Chat - Anything with wheels
    Last Post: 08-09-2008, 02:47 PM
  5. Please Help Oil Pressure/Red Oil Light
    By misterme23 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-06-2008, 10:07 PM
