Thread: Does the Tyre pressure Monitor actually work ?
Results 1 to 10 of 10
  1. Does the Tyre pressure Monitor actually work ?
    Jul 2012
    Hampshire, UK
    Had the misfortune to pick up a rather large screw in one of the front tyres the other day, resulting in a puncture. As the screw was firmly embedded, there was no sudden deflation and I expect it might even have taken a couple of days to deflate to the point where it was visibly obvious. My wife mainly drives the car and she hadn't noticed anything wrong, but more concerning was the absence of any complaint from the TPM. I had recently adjusted the tyre pressures over Xmas and reset the TPM so it should have worked or am I missing something?
    Mine - 2011 A7 3.0 TDi Quattro SE
    Hers - 2013 Mk7 Golf GT 1.4 DSG
  2. Re: Does the Tyre pressure Monitor actually work ?
    Apr 2013
    Kent
    Possible that It wasnt letting any air out at all...
    mine works perfectly (on audi) and is quite sensitive. Easy way to check is let some air out when your next at the petrol station and see if it triggers?
  3. Re: Does the Tyre pressure Monitor actually work ?
    Jul 2012
    Hampshire, UK
    It let all the air out allright, albeit over a couple of days. The one on my Audi also works fine, just seems the one on our Golf doesn't.
  4. Re: Does the Tyre pressure Monitor actually work ?
    Jan 2014
    Scotland
    Quote Originally Posted by Avidfanofstuff View Post
    The tyre pressure monitor works on the ABS sensor picking up changes to the momentum of the wheel rotating caused by deflation of the tyre. If you let air out of the tyre when the car is static, the TPM will definitely not trigger a warning.
    2 0 0
  5. Re: Does the Tyre pressure Monitor actually work ?
    Apr 2013
    Kent
    Quote Originally Posted by mattlittle View Post
    Cheers for that. Nothing is simple these days is it!
  6. Re: Does the Tyre pressure Monitor actually work ?
    Dec 2013
    North Yorkshire
    It won't trigger while stationary but should when you start moving. As I understand it the TPM uses the ABS sensors to compare relative rotation of the different wheels. A wheel/tyre with lower pressure will have a smaller rotating circumference and hence greater rotation for a given speed than the other wheels. This is what the TPM detects.
    2010 S4 Avant B8
    Black Pearl c. black style pack & 19" 5 seg. wheels: drive select (+ damper control, dynamic steering); sports diff; ssports seats in black/magma, heated; conv. pack (mem seats/folding mirrors); carbon atlas inlays; tech pack high (HDD satnav, MMI, AMI); B&O; cd changer; mobile phone prep; parking system adv; hill hold; high beam assist; power tailgate; privacy glass; side blinds; storage pack; through load; tow pack
  7. Re: Does the Tyre pressure Monitor actually work ?
    Jan 2014
    Scotland
    Quote Originally Posted by ziggycol View Post
    Good point - I mentioned it as I assume that the suggestion of letting air out at a garage was that it was easy to refill from a garage's air supply before going back on the road.
  8. Re: Does the Tyre pressure Monitor actually work ?
    Jan 2013
    Slough
    Mine has worked twice. Early on in the car's life the tyres were massively over inflated by the garage. One tyre lost some of that, and the pressure warning came on. I reset it and changed the pressures on all four. It came on some months later as one had lost a smallish amount. Pumped up and re-set.
  9. Re: Does the Tyre pressure Monitor actually work ?
    Mar 2013
    Cardiff
    Given how the ABS sensors work then the TPM is never going to be fool proof. It's a guide and may help you if you get a puncture at high speed but it's no substitute for regular checks IMHO.
    Probably in a pit underneath a steam loco somewhere.
  10. Re: Does the Tyre pressure Monitor actually work ?
    Aug 2008
    Mine certainly worked.
    Tyre Pressure monitoring is something I have never had on a car before – but wow was it useful the other day. Backing out of the garage the TPMS light/warning came on. A screw had punctured the tyre tread leading to a gradual (not complete) loss of pressure. I was able to put the car back into the garage, take the wheel to my local tyre dealer for a fix.
    Without TPMS I would have set off on my long journey on a wet, manky day and would have ended up being stranded on the roadside changing a wheel.
    Guy
    2.0tdi GT DSG, Pacific Blue, Vienna "Shetland" leather sports seats, Discover Pro Nav system, Colour multifunction display, 2-zone Climate control, steel door sill trims, Rear chrome strip
  1. Tyre Pressure Monitor
    By icebun in forum Golf MK6 - 2009 - 2013
    Last Post: 06-02-2010, 03:31 PM
  2. Tyre Pressure Monitor
    By alexcf in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-08-2009, 10:26 AM
  3. Question How does the Tyre Pressure Monitor system work?
    By Bratty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-05-2009, 11:58 AM
  4. Tyre pressure monitor
    By jimgironde in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-01-2009, 06:33 PM
  5. Tyre Pressure Monitor
    By Black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-05-2008, 08:55 AM
