Thread: Can I bypass EGR Cooler on a BKD?
  1. Can I bypass EGR Cooler on a BKD?
    Mar 2008
    Birmingham
    I've started to white smoke and disabling the EGR valve at the front seems to stop this so I am assuming the cooler is leaking internally. Can I disconnect and bridge the coolant feed to it and drive it like that for a while without causing any damage?
    Any advise would be much appreciated.
    Thank you
    2011 A3 2.0 TFSI Quattro S-Tronic S-line Black Edition
    2004 A3 2.0 TDI 140 Sport
    1998 Golf 1.6 8V SR 110 SE
  2. Re: Can I bypass EGR Cooler on a BKD?
    Sep 2008
    VAG 2.0 TDI EGR Roadsport Delete kit - FR&R Tuning| MAHA Dyno Rolling Road Tuning| Stage 1, 2 & 3 Engine Performance Upgrades
    By pass kit. Checked it out when mine was sticking. Don't know if this is what you were asking.
  3. Re: Can I bypass EGR Cooler on a BKD?
    Mar 2008
    Birmingham
    Hi Fexo, Thanks for the reply.
    I would love to do the delete kit but with the MOT and the emissions light I'm going to avoid that for now. I just wanted to know if I could leave it in tact and just by pass the cooling part of the EGR so non of the coolant is flowing through it for now until I get a new cooler.
    I would be using something like this: http://www.machinemart.co.uk/shop/pr...6in-hose-joint
  4. Re: Can I bypass EGR Cooler on a BKD?
    Mar 2008
    Birmingham
    Cooler will be with me on Tuesday so I'm not going to bother with the bypass.
    Does anyone have any tips on removal and installation?
    I believe I need to get under the car and remove the intake pipe on the turbo to access bolts but looks pretty straight forward otherwise.
  5. Re: Can I bypass EGR Cooler on a BKD?
    131 Post(s)
    1979 Post(s)
    I am glad you are not going to compromise your cars emissions system, it is environmentally irresponsible to take off cats, DPF's and EGR systems.
    The cooler is OK to do. Take the air cleaner system and valve block out and remove the turbo air induction pipe and you can easily get to it, the official time is 1.6 hours but allow yourself 2 hours.
  6. Re: Can I bypass EGR Cooler on a BKD?
    Mar 2008
    Birmingham
    Hi Crasher, thanks for your reply. When you say the valve block, is that the valve attached to the end of the cooler? I think its also known as the change over flap if its what I'm thinking?
  7. Re: Can I bypass EGR Cooler on a BKD?
    131 Post(s)
    1979 Post(s)
    No, the combined vacuum valve unit on the bulkhead, it gets in the way.
  1. Question ASZ 130BHP have an EGR Cooler and what size EGR delete kit do i need? 51mm or 57mm?
    By geoff eeles in forum Golf MK4 - 1999 - 2004
    Last Post: 30-10-2013, 12:54 AM
  2. Question EGR cooler bypass/delete ??
    By fastbikes76 in forum Touran - Sharan - Caravelle
    Last Post: 10-03-2012, 03:06 PM
  3. EGR Bypass
    By redducati in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-03-2011, 12:06 AM
  4. egr bypass - emissions workshop
    By deetee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2010, 01:05 PM
  5. Question how to bypass the EGR valve...?
    By cusford in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-12-2009, 02:18 AM
