Thread: ABS, EPS and EPB warning lights problem
  1. ABS, EPS and EPB warning lights problem
    East central Scotland
    Have an intermittent problem with ABS, EPS and EP warning lights coming on. ABS and EPS are static when on and EPB flashes. Auto hold cancels when this happens.
    Happens only occasionally and clears when ignition turned off and then on again. Can go a couple of weeks between occurrences but occasionally will happen 2/3 times a journey. Happens day or night, wet or dry, straight line or cornering without any obvious similarity of circumstances.
    All pads and discs were replaced three months ago.
    EPB works ok.
    Any ideas? Loose wire/connection maybe?
    Thanks, Peter
  2. Re: ABS, EPS and EPB warning lights problem
    Norfolk
    A vcds scan may show some warnings that don't show up in a fault scan.
  1. Please help! ABS/EPS Warning Lights
    By ahmadcorp in forum VCDS - Help Requests
    Last Post: 02-07-2013, 11:34 AM
  2. Please Help EPS/ABS Warning Lights
    By grahamchet in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-10-2012, 09:14 PM
  3. EPS/ABS Lights
    By grahamchet in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-10-2012, 12:48 PM
  4. Replies: 1
    Last Post: 24-02-2012, 10:04 PM
  5. abs and eps warning lights on
    By BROWN_OWL in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-08-2007, 08:50 AM
