Thread: some allroad vag com codes
  1. some allroad vag com codes
    Jul 2007
    just put my 2002 allroad on my vag com and got these codes.may be off help to some one
    Address 08 -------------------------------------------------------
    Controller: 4B0 820 043 AB
    Component: A6-Klimavollautomat 0105
    Coding: 00004
    Shop #: WSC 02325
    1 Faults Found:
    01592 - Air Quality Sensor (G238) £65 from *******'s
    37-00 - Faulty
    Skipping Address 15-Airbags
    Address 35 -------------------------------------------------------
    Controller: 4B0 962 258 K
    Component: Zentralverrieg.,DWA D35
    Coding: 06863
    Shop #: WSC 02325
    6 Faults Found:
    01366 - Opened Due to Crash Signal reset not came back
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch new handel mec fitted £35
    35-00 - -
    00956 - Key 2
    09-10 - Adaptation Limit Surpassed - Intermittent.
    Key operated more than 200 times while out of range
    This procedure must be performed after changing the batteries in remote keys, or if the fault reader displays fault codes 00955 to 00958.
    • Press key on remote key.
    If vehicle is neither locked nor unlocked:
    • Lock and unlock vehicle within 30 seconds by way of driver's door lock.
    • Then check function of re-matched remote key.
    01561 - Left Rear Door
    59-00 - Can't Unlock I need help here it is unlocked
    01561 - Left Rear Door and here
    61-10 - Won't De-Safe - Intermittent and here
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00002
    Shop #: WSC 02325
    3 Faults Found:
    01403 - Glass-Break Sensors: Rear This is making my alarm go off at early in the morning and late at night
    36-10 - Open Circuit - Intermittent
    35-00 - -
    01384 - Alarm triggered by Glass Breakage Sensor
    35-00 - -and this
    the alarm is most impotent as its doing me head in
  2. Re: some allroad vag com codes
    Feb 2007
    Are you still experiencing problems with the alarm/glass breakage sensors on your car??
    I am having similar problems and would be interested to know if you got to the bottom of it.
    thanks
    djl
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  3. Re: some allroad vag com codes
    Jul 2007
    once i replaced the boot locking mec and cleared the codes its has been fine.oh and i dryed the carpet on the passanger side,after having the grommit removed from under the battery.
  4. Re: some allroad vag com codes
    Removing the grommets ( there are 2, one under the battery and one under the servo ) is not ideal. The reason for the grommets it to let water out of the plenum chamber but not let air/engine fumes in form the engine/gearbox area. The air that enters the plenum chamber is from the postive pressure against the windscreen and this air passes through the pollen filter into the car. However at more than about 10mpg that is enough positive pressure to feed the pollen and force air out of the grommet holes. Regards Peter
  1. allroad tdi 2.5 air in fuel :(
    By m6rk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-12-2007, 01:09 PM
  2. Allroad Tyre Wear
    By Neil Young in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-08-2007, 11:40 AM
  3. Allroad 155ps version?
    By pdk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-06-2007, 10:51 PM
  4. Allroad pre-purchase inspection
    By Wolvo in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 23-04-2007, 12:11 PM
  5. Allroad anti hijack locks
    By wantmygti in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-03-2007, 06:12 PM
