Thread: my 1.8T is poorly , missing and running on 3 help.
  1. my 1.8T is poorly , missing and running on 3 help.
    Dec 2008
    hi only just started today but its been a cold day today the coldest its been since ive had the a4 but i drove it quite hard and it goes from tickover to about 3000rpm and it misses and runs on 3 cylinders for a few seconds then its ok till the next time , ive pulled the coil packs off and one of them is really hot for some reason , ive got 2 bosch and 2 non discript , the car is a 2002 with 165k on it , would it still quallify for a coil recall if its that
    i had the engine light flashing while it was missing if anyone can help my engines a avj and the codes were 16804,had this for a while but comes back after clearing , the next 3 are new today 16684 , 16687 & 16891 , please help lol thanks
  2. Re: my 1.8T is poorly , missing and running on 3 help.
    Southern County Softy
    20 Post(s)
    Dont run a car with a misfire you can damage the CAT=big bill.
    Sent from my GT-I9305 using Tapatalk
    A4 2.5 tdi QS (mapped)
  3. Re: my 1.8T is poorly , missing and running on 3 help.
    Dec 2008
    i had a bit of oil that had squeezed out of the rocker cover at the back , i think my prv was blocked just abouve the turbo that hockey puck shaped thing , seems ok now , tomorrow will tell , just worrying the coil pack 3 was hot can i still recall these?
  4. Re: my 1.8T is poorly , missing and running on 3 help.
    Sep 2012
    Fife
    Phone Audi UK with your chassis number & they will tell you if your car has had the coil packs changed in its lifetime at their expense - remember they'll only do it once! After that it's up to you. If your prv was blocked all the associated pipe work will be too. You need to take it apart & give it a good clean out - a rag, an old wire coat hanger & some solvent work at treat.
  5. Re: my 1.8T is poorly , missing and running on 3 help.
    Dec 2008
    good news the recall hasnt been done on my car but the trouble is ive got 2 bosch genuines and non genuines and its one of the non gens thats at fault , they said they would only change the genuine ones for me i could do with 2 more faulty gens to pop in has anyone got any to send me please.lol
    today it did it again and the eng light flashed it said 16687 cylinder 3 missfire so i swapped the coil pack with cylinder 1 and cleared the fault , and later today it came up with a flashing light again and a fault code of 16685 cylinder 1 , has anyone got 1? cheers
  1. Golf Mk 4 100 pd tdi missing/running on 3
    By cdhazell in forum Golf MK4 - 1999 - 2004
    Last Post: 26-09-2009, 09:41 PM
  2. Please Help Poorly 1.8T
    By richjthorpe in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-09-2008, 05:09 PM
  3. Poorly Polo running a temperature
    By side-show-bob in forum Polo - Derby - Lupo - Fox
    Last Post: 13-01-2008, 02:33 PM
  4. Replies: 4
    Last Post: 26-09-2007, 02:13 PM
  5. poorly s2
    By fraze in forum Archive posts
    Last Post: 04-07-2007, 10:16 PM
