Thread: Strange 'almost stop-start judder' if revs lower than idle
  1. Question Strange 'almost stop-start judder' if revs lower than idle
    Dec 2013
    I've got an odd (and somewhat annoying) issue with my motor (had this since I bought it in July).
    If the revs drop any lower than idle (900 give or take) - even by a fraction, the car feels like it's almost stopping, then restarting. In some instances recently it'll cut out completely.
    Now I've driven many a car (inc. diesels), and I know what it's like when you 'kangaroo' them - it's certainly not the same feeling. It's much sharper and much more vicious.
    I appreciate that if I rev slightly more when pulling away it'll be fine, just wondered if there is something else I need to review...
    2007 S Line TDi Quattro 170
  2. Re: Strange 'almost stop-start judder' if revs lower than idle
    Mar 2008
    Birmingham
    Had a similar feeling with mine after clutch and flywheel and at the time I knew the lower rear engine mount was gone but had to wait for parts so drove it a while and it felt as you describe. I would suggest you inspect this (http://www.034motorsport.com/images/11_Mk5_DB.jpg) and there is a good bit of info about uprated parts here (VWVortex.com - *** NEW : MKV Density Line Engine Mount & Dogbone mount - 169US SHIPPED). I went with OE.
    2011 A3 2.0 TFSI Quattro S-Tronic S-line Black Edition
    2004 A3 2.0 TDI 140 Sport
    1998 Golf 1.6 8V SR 110 SE
  3. Re: Strange 'almost stop-start judder' if revs lower than idle
    Mar 2008
    Birmingham
    On second thought I also had the cam belt and water pump done at the same time so may be link to that more than the mount. Ignore my above advise and start with a code scan with VCDS.
  4. Re: Strange 'almost stop-start judder' if revs lower than idle
    Dec 2013
    Cheers!
  1. any 2.0 tdi owners with judder / strange idle problem
    By jase682 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-09-2011, 08:57 PM
  2. Question fast idle & strange cold start
    By cookie7354 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 07-02-2010, 10:06 PM
  3. Idle erratic, revs dont come down quick when come to a stop!
    By enright86 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2008, 02:39 PM
  4. Strange idle,revs,engine stall
    By graeg76 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-11-2008, 08:14 AM
  5. Strange idle, start up and accelerator problem!
    By AsaTDi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-09-2008, 09:00 PM
