Thread: Setting Distributor timing on a 1.8 ABS Engine mk3 golf?
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Setting Distributor timing on a 1.8 ABS Engine mk3 golf?
    Cheers guys, I guess I need that 2x2 cable too.
  2. Re: Setting Distributor timing on a 1.8 ABS Engine mk3 golf?
    I'm still having a bit of nightmare with this car (our daily hack).
    After behaving for a while (many days usually), it'll start to pink like crazy when the engine is under any sort of load. Not wishing to knacker the engine, I generally jump out & retard the ignition when this happens which cures the pinking problem & the car drives & pulls fine.
    It'll then run fine again for a few days or even weeks, then out of the blue it decides to be incredibly sluggish when driven from cold for the first few miles (as if the timing is severely retarded) only improving when warmed up & then still not feeling on top form. I've been then advancing the ignition again which brings back the power but doesn't bring back the pinking.
    The cycle then starts over again & has happened at least half a dozen times now.
    I'm thinking that there must be a dodgy sensor somewhere telling the ECU not to advance the timing, but can anyone suggest which it might be before I go just randomly changing them?
    VAGCOM doesn't show any faults
  3. Re: Setting Distributor timing on a 1.8 ABS Engine mk3 golf?
    133 Post(s)
    1991 Post(s)
    You could drop a house on those ECU's and they wouldn't detect a fault. You need to get the ignition timing checked.
  4. Re: Setting Distributor timing on a 1.8 ABS Engine mk3 golf?
    I guess so, but why would the fault be intermittent if it was just a case of the timing being awry? It's a huge difference...
  5. Re: Setting Distributor timing on a 1.8 ABS Engine mk3 golf?
    133 Post(s)
    1991 Post(s)
    The ECU can adapt to the timing but then lose that adaptation but the timing is the first place to start seeing as the dizzy has been moved if I remember correctly.
  1. Replies: 2
    Last Post: 10-01-2008, 02:18 PM
  2. Golf Gt tdi (140) Sump plug torque setting.
    By richard_vw in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-08-2007, 10:54 AM
  3. My Distributor Fallen To Bits
    By windy1978 in forum 80 - 90
    Last Post: 26-07-2007, 09:38 PM
  4. Seat Inca Timing Problems VW 1Y engine
    By Trotter in forum Archive posts
    Last Post: 17-07-2007, 08:50 PM
  5. Re-setting Dash warning lights On Mk V5 Golf
    By AndyV5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-06-2007, 05:50 PM
