Thread: Caliper mounting bolts on '98 Passat
  1. Caliper mounting bolts on '98 Passat
    Jan 2014
    A, A
    Hi guys,
    i'm in a bit of a pickle, as I am without my car at the moment but need to buy a tool to remove my rear caliper on my 1998 Passat tonight - performing the job tomorrow.
    They seem to be allen head bolts (I was expecting a regular bolt) but i'm not sure of the size of the allen key that is required.
    Can anybody let me know what size i would need to pick up from my local motor factors, so I don't have a wasted trip on my way home from work.
    I appreciate any advice you can give
    Cheers,
    Matt
  2. Re: Caliper mounting bolts on '98 Passat
    8mm off the top of me head.
  3. Re: Caliper mounting bolts on '98 Passat
    london/ UK
    Yep, 8mm but buy a good quality tool and breaker bar and possible big mole grips if you round the heads off ! Just for your info, the discs come off without taking the carriers so you don't need to buy any special tools apart from the brake piston winder !
    The calipers are held on the carriers with 2x 13mm bolts and you need a slim 15mm spanner to counterhold the sliding pins...
  1. removing the caliper mounting , to replace brake discs; B6 saloon
    By markh75 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-01-2014, 06:25 PM
  2. Question Bolts for brake caliper '7mm Hex bolts'
    By geoff eeles in forum Golf MK4 - 1999 - 2004
    Last Post: 01-08-2012, 07:59 PM
  3. Please Help Rear Caliper Mounting Spline Bit?
    By paulomarto in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-07-2011, 03:28 PM
  4. Front DS caliper mounting bracket
    By Canetoad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-10-2010, 11:30 AM
  5. Mk 3 Tdi Rear engine mounting bolts.
    By Jud6572 in forum Golf MK3 - 1993 - 1999
    Last Post: 05-09-2009, 09:24 AM
