Thread: A4 2.0tfsi Quattro - quick but not as quick as i thought - problem?
  1. A4 2.0tfsi Quattro - quick but not as quick as i thought - problem?
    Jan 2014
    Sweden
    Hi everyone!
    I am a proud owner of a 2006 2.0tfsi avant quattro. It really looks the part!
    We have owned it a month or 2 now. it is quick, since the shine of buying it has worn of a little, I cant help but feel that it should be quicker.
    It pulls really smooth, and accelerates fine. I think there should be more power though. I owned a 1.8ts A3 quattro some years back and that was definitely quicker.
    Though that is where my experience with turbo cars ends. I can really feel the turbo on the A4 "kicking in". I didnt expect a kick in the back, when the boost came on, but something. I also cant hear the boost, I assume that is because it is a low boost system. or should I be able to hear it?
    I bought a vag fault code reader today and didn't find any codes, so i guess thats good. I have done lots of reading on here and elsewhere on similar issues: I tried the PCV valve diagnosis, feeling form sucking from the oil filler cap. there was tiny amount of vacuum (but of course there should be right?). I also would suspect the diverter valve, but as i said no fault codes were on the car. So could it still be that?
    All input really welcome....
    Craig
  2. Re: A4 2.0tfsi Quattro - quick but not as quick as i thought - problem?
    Feb 2013
    Gloucester
    57 Post(s)
    When the mrs was shopping for her A5 we too test drove the 2.0 Quattro and were thoroughly underwhelmed. Guess it's just an underpowered engine.
    Audi A7, S-line, 313 PS BiTDI Tiptronic, Daytona Grey, heated front and rear seats, Audi connect, quad zone climate control, ski chute and bag, Rear tints, 75 Litre fuel tank, All LED headlights, Night vision assistant, Rear view camera with corner view, Navigation plus, MMI touch, Heads up display, Adaptive Cruise control, Blind spot monitoring and active lane assist. Audi A5 (wifes) My Kit car blog - http://mitchsgbszero.blogspot.co.uk
  3. Re: A4 2.0tfsi Quattro - quick but not as quick as i thought - problem?
    Mar 2007
    9 Post(s)
    i had the same problem with mine just replace the turbo diverter valve it cost me £44.00 from awesome gti completely transformed the car . there is a thin rubber diaphram that splits but does not show up on vcds as technicaly the valve is stiil working mechanically but due to the split is unable to carry out what it is meant to do
    Quote Originally Posted by quattroorcooper View Post
    Hi everyone!
    Craig
  4. Re: A4 2.0tfsi Quattro - quick but not as quick as i thought - problem?
    Jan 2014
    Sweden
    Quote Originally Posted by sbt View Post
    Good stuff! I just ordered one and will update when it is fitted. fingers crossed.
  5. Re: A4 2.0tfsi Quattro - quick but not as quick as i thought - problem?
    Aug 2009
    Near Lanark
    21 Post(s)
    You won't hear the turbo because of the design of the engine. A subaru and cosworth has a "whoosh" because it has a dump valvle. Audi doesn't have that, it recirculates the air and doesn't dump it through a whooshing valve. So if the diverter valve splits or tears, you lose some of that recirculation and the power drops.
    It's also not designed to give you a "kick" the way you might expect.....I think that's deemed too aggressive. Fine for cossies and Subarus but you get more lag before a kick....smaller turbo means less lag but less "kick"
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  1. Quick question needs a quick answer please
    By Seboni121 in forum Golf MK6 - 2009 - 2013
    Last Post: 07-03-2012, 06:32 PM
  2. PS problem- quick answer please
    By densel16 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-02-2011, 12:41 PM
  3. Please Help Clutch Problem ?, anyone give a quick diagnosis ?
    By Mr Sco in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-03-2010, 09:34 PM
  4. Replies: 1
    Last Post: 07-08-2009, 04:31 PM
  5. quick question quick answer needed please
    By minty0_10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-10-2008, 01:02 AM
