Thread: Vacuum Pump?
  1. Vacuum Pump?
    Nov 2013
    Newcastle Upon Tyne
    Hi guys, quick question - the black hose pictured below is that part of the vacuum pump?
    Also should it be bouncing up and down when the engine is running e.g popping in an out?
  2. Re: Vacuum Pump?
    Nov 2013
    Newcastle Upon Tyne
    Someone on youtube with the same problem.
  3. Re: Vacuum Pump?
    Aug 2011
    Meath
    That looks a vacuum hose, looks like there's wear on the connection. Secure it with duct tape until you get it fixed
  4. Re: Vacuum Pump?
    Nov 2013
    Newcastle Upon Tyne
    Quote Originally Posted by Doctle Odd View Post
    Hi thanks for the reply.
    Should it be popping in and out like that so violently? Surely that means the seal has gone and air will be getting in?
    Rob.
  5. Re: Vacuum Pump?
    Nov 2013
    Newcastle Upon Tyne
    Checked it again this morning and its stopped popping in and out, however if I sit parked up when the engine is idling if I pump the brake pedal the idle rpm goes up, each time I press the brake pedal the engine rpm increase by about 100 rpm.
  6. Re: Vacuum Pump?
    Aug 2011
    Meath
    Hence the duct tape until you get it fixed!
  7. Re: Vacuum Pump?
    Nov 2013
    Newcastle Upon Tyne
    Unsure where I will place the tape as the problem is internal to the pump e.g the actual mating face to the hose pops in and out like turtles head in ya trousers.
  1. How To Exhaust vacuum pump
    By Nemo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-03-2012, 01:19 PM
  2. Vacuum Pump/Unit ???
    By robahern in forum Golf MK5 - 2004 - 2009
    Last Post: 09-07-2009, 01:36 PM
  3. Vacuum pump (tandem pump)
    By audi_130bhp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2007, 12:44 PM
  4. Vacuum Pump Leaking Oil. What does this mean??
    By lennymfo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-10-2007, 05:19 PM
  5. electric vacuum pump
    By gaz238 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-03-2007, 04:45 PM
