Thread: lupo stalled. now starts but immediately stops, epc light somtimes does not come on
  1. Unhappy lupo stalled. now starts but immediately stops, epc light somtimes does not come on
    Jan 2014
    bagshot surrey
    hi 2003 1.4 petrol. 16valve lupo died at traffic lights while idling. wouldnly start and then stop. rac man connected computer but not recognised! epc light was not coming on when turning on ignition. battery was very low due to trying to start and lights on using rac mans booster. checked fuses but towed home as could not fix. I recharged battery 24 hrs now epc light does come on when turn on ignition, when starting turns over and immediately stops tried 20 times but the same. forums suggest immobiliser. I have tried with our 2 keys but same, any expert got any other ideas? thanks rick
  2. Re: lupo stalled. now starts but immediately stops, epc light somtimes does not come on
    Oct 2005
    Welcome to VWAF
    Starts and then stalls suggests an immo problem - do you have any dash lights?
    You need a fault code scan before you do anything. What do you mean by "rac man connected computer but not recognised!"
  3. Re: lupo stalled. now starts but immediately stops, epc light somtimes does not come on
    Southern County Softy
    20 Post(s)
    Does the engine start then cut out ?
    You could try changing the battery in the key.
    A fault scan would help.
    Sent from my GT-I9305 using Tapatalk
    A4 2.5 tdi QS (mapped)
  4. Re: lupo stalled. now starts but immediately stops, epc light somtimes does not come on
    Pembrokeshire
    22 Post(s)
    check all the fuses. not sure which one goes but i seem to remember a fault where a pretty important wire chaffes somewhere and causes the fuse to blow. its one of the normal blade fuses in the fuse box. gives the same result as a dodgy immobiliser because iirc it powers the fuel pump.
  5. Re: lupo stalled. now starts but immediately stops, epc light somtimes does not come on
    Jan 2014
    bagshot surrey
    hi yes all electrics and dash lights etc work. the epc light now comes on every time before starting then goes off but car immediately stops and epc light comes on again. when rac man plugged his laptop into car under ash tray the software was not recognising the car but that was when the epc light was not coming on
  6. Re: lupo stalled. now starts but immediately stops, epc light somtimes does not come on
    20 Post(s)
    Do have home start ? Get the RAC to rescan.
  1. Starts then Immediately Cuts Out
    By MarkSRose in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-01-2013, 01:11 PM
  2. Please Help 52 reg 1.4 16v Lupo SE has EPC light, Engine check light and stiff brake pedal
    By robbig in forum Polo - Derby - Lupo - Fox
    Last Post: 02-09-2008, 10:45 PM
  3. Please Help GTI 16v starts then immediately dies!
    By mikecarty51 in forum Golf MK3 - 1993 - 1999
    Last Post: 29-08-2008, 08:17 PM
  4. 96 sharan starts then stops,immob light flashes
    By madmum in forum Touran - Sharan - Caravelle
    Last Post: 05-06-2008, 11:43 PM
  5. A3 2.0 Fsi Engine starts but cuts out immediately
    By A3_2FSI in forum Audi A3 - Archive Topics
    Last Post: 13-02-2008, 12:43 AM
