Thread: Traffic sign recognition nearly coded
Page 4 of 22 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 217
  1. Re: Traffic sign recognition nearly coded
    #31
    Sep 2012
    London, UK
    Hi guys,
    Sorry to restart such an old thread but I coded the VZE on my new A6 4G following your indications: the first time all the necessary bits were there and coded. Of course I was getting all the same speed messages as you.
    Then the DIS start screen changed into the RS6 one and even with the appropriate coding I could not revert to standard (00 for standard A6). Went back into my VCDS logs and copied the original cluster long coding. Obviously I have the VZE still active in 5F, 85 and 8E but cannot find anymore where to activate it in the cluster 17 Byte 05 bit 2 - cannot see beyond bit 1 as Ndiye in post #7 - it's like I have a different cluster now and I am not sure how to activate the additional bits because with 01110011 as in your example I just get a spoiler error.
    Any idea?
    Audi A6 Avant 4G 3.0 Tdi Quattro S-Line - Daytona Grey, Matrix Lights, Tech Pack Advanced, Headup Display, Rear Camera, Park Assist, Front/Rear Heated Seats, Advanced Keys, Adaptive Suspensions
  2. Re: Traffic sign recognition nearly coded
    #32
    Sep 2012
    London, UK
    Fixed it...
  3. Re: Traffic sign recognition nearly coded
    #33
    Feb 2013
    Gloucester
    57 Post(s)
    Fixed your fault or didi you get the traffic recognition to work?
  4. Re: Traffic sign recognition nearly coded
    #34
    Sep 2012
    London, UK
    I changed Byte 5 directly in the Long Coding from 41 to 15 and the VZE is now back in both cluster and MMI. I have "Assist" as well in the DIS now, not sure how to get a rid of it.
    As for the VZE to work, not there yet.
    Just wondering, the security code for the 8E module does not seem to work...Maybe it needs three pins one after the other as my old 4F 55 Headlight Control module?
    BTW, anyone knows what the other bits in Byte 5 activate?
  5. Re: Traffic sign recognition nearly coded
    #35
    May 2014
    Bath, UK
    I was browsing Kufatec today and remembered this thread. They sell a few versions of the "kit" that has what they think is needed...
    http://www.kufatec.co.uk/shop/en/aud...-audi-a6-a7-4g
    Active Lane Assist incl traffic sign recognition Audi A6, A7 4G-40210
    Diagnostic interface traffic sign recognition-40225_M
  6. Re: Traffic sign recognition nearly coded
    #36
    Feb 2013
    Gloucester
    57 Post(s)
    yeah I've seen those too, however after sending my VIN, they quoted nearly £500 to fit the bits I need!
  7. Re: Traffic sign recognition nearly coded
    #37
    Aug 2014
    Quote Originally Posted by M1tchy View Post
    What bits do they say you need? I thought the only pre-reqs were the image processing unit (which comes with ACC/Active Lane Assist) and MMI Plus?
    If you look at Audi's self study booklet for speed limit display http://admin.audionlinetraining.com/...0indicator.pdf), it mentions the errors that can appear when traffic sign recognition isn't working. Looks like something else needs coding in the MMI to send live route data to the image processing unit in order for the traffic sign recognition to work.
    Page 32 of that document shows which modules are involved in traffic sign recognition. They include the electrical system control unit, which the sends windscreen wiper status to the image processing module. Wonder if anything needs coding in this to make it work?
  8. Re: Traffic sign recognition nearly coded
    #38
    Feb 2013
    Gloucester
    57 Post(s)
    The link doesn't work for me I'm afraid mate. I thought I had all the hardware too as I have ACC and lane assist. I've emailed Audi and asked them as I forgot to spec it, can they add it for me and I will pay. If they do then I will know exactly how it's done!
    There is a tread in the A6 forum that suggests changing the image processing module from GB to RoW makes it work. Haven't had chance to have a play yet though.
  9. Re: Traffic sign recognition nearly coded
    #39
    Aug 2014
    Strange - works ok here. Google "Audi Ssp 482" and you should find it. :-)
  10. Re: Traffic sign recognition nearly coded
    #40
    Feb 2013
    Gloucester
    57 Post(s)
    Got it! Thanks.
    It says if it says outside of operational area then it's not coded for the correct country. I will have a look tomorrow to see if I can find how to change the country as that is the fault I was getting after trying to code it.
    Sent from my iPad using Tapatalk HD
  1. Traffic Sign Display missing
    By Evil Dan in forum Golf MK7 - 2013 - 2019
    Last Post: 11-09-2013, 11:52 AM
  2. Voice recognition issue
    By ttamlleb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-08-2013, 04:08 PM
  3. Passat SE Voice Recognition
    By laurona12 in forum In Car Entertainment
    Last Post: 16-07-2011, 10:33 AM
  4. Code Fault Recognition
    By csducks in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-01-2010, 10:10 PM
  5. Voice Recognition - No Function
    By Blackavant in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-04-2009, 03:09 PM
