Thread: Traffic sign recognition nearly coded
Page 3 of 22 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 217
  1. Re: Traffic sign recognition nearly coded
    #21
    Feb 2013
    Gloucester
    57 Post(s)
    You definitely deserve the credit, you pieced it all together and now it works perfectly. Thanks again.
    Do you have an email address I can send the screen shots to? I don't know what other info is available from a VCDS scan (VIN, reg etc) so not massively keen on posting them on the internet. Happy to email them to you as an individual though.
    I'm a Sgt in the British Army. I'm in communications and specifically Electronic Warfare by trade hence why I like to figure things out - probably the same for you.
    Over the next week or so I'm looking at doing a VCDS tricks thread for A7 owners, just like they have in the A6 thread. Obviously crediting you, and clearly stating that we are not responsible for any errors in programming, are you happy for me to add your boot closing coding to the list? And if we sort this traffic sign recognition, your part of this too?
    Sent from my iPad using Tapatalk HD
  2. Re: Traffic sign recognition nearly coded
    #22
    Oct 2011
    Birmingham
    I've PM'ed you . . . . . .
  3. Traffic sign recognition nearly coded
    #23
    Feb 2013
    Gloucester
    57 Post(s)
    Thanks for your message.
    I've got one of the screen shots you were after, will get the other and PM you in the morning.
  4. Re: Traffic sign recognition nearly coded
    #24
    Feb 2014
    Moscow Russia
    Hello, M1tchy
    As far I understand from your discussion with Ndiye, you have activated this function succesfully. I try to do it on my A6 C7 using different information from forums but have no result. Would you help me with instructions?
    Thank you in advance.
  5. Re: Traffic sign recognition nearly coded
    #25
    Feb 2013
    Gloucester
    57 Post(s)
    Hi, we havnt quite got it working yet. The only bits we have managed is what is posted in this topic. It doesn't work properly yet I'm afraid.
  6. Re: Traffic sign recognition nearly coded
    #26
    Feb 2014
    Moscow Russia
    May be we can change information and resolve it?
  7. Re: Traffic sign recognition nearly coded
    #27
    Feb 2013
    Gloucester
    57 Post(s)
    All we have managed to do is
    - 17 Instruments, Long Coding, Byte 05, Bit 2 on
    - 8E Image Processing, Long Coding, Byte 02, Bit 0 on
    - MMI Hidden Menu: car/cardevicelist, VZE on
    - MMI Hidden Menu: car/carmenuoperation, VZE to level 5
    This shows the traffic sign recognition camera in the MMI but doesn't read the signs. Have you got any further?
  8. Re: Traffic sign recognition nearly coded
    #28
    Oct 2011
    Birmingham
    Hey M1tchy
    I haven't had a lot of time on my hands lately, but I thought I'd share the little tidbit I found, you know how when you try to change the adaptations for 8E image processing module, there is need for a security code? I came across a code in my travels on the web tried it and it was accepted, yeah right? The thing is even though the code is accepted as correct, still can't make any changes to any of the adaptations, maybe you can have a go, you might succeed where I failed. The code I used is 20103.
    2016 A7 BiTdi Black Ed. Misano Red Tech Pack, Parking pack and more . . . .
  9. Re: Traffic sign recognition nearly coded
    #29
    Feb 2013
    Gloucester
    57 Post(s)
    That's great thanks. My car is going into Audi tomorrow fort he week so will have a play when it back. I've been away with work a lot recently too so not had much chance to play.
  10. Re: Traffic sign recognition nearly coded
    #30
    Feb 2014
    Telford, Shropshire
    Hi, just a a thank you ref the auto boot close on my A7 - I have convenience key but without the keyless entry (accidentally wrote "legless" entry originally ) & am looking to retro-fit keyless. The auto boot from the key fob works fine and there were no issues.
    On my car though, when trying to do the High Beam Assist range adjustment, VCDS can't communicate with module 20 - its like its not there, however I do have the HBA option on the car because it works quite well. As VCDS tries to communicate with the module, you can see that it is trying the high-beam assist module - but the module never replies and VCDS tries the suite of protocols...I tried this several times by the way - just like the module isn't installed?? I wonder if I'm using VCSD wrongly - I used the short-cut but typing in the module number at the bottom.
    Also interested in the part number of you BCM (next time you go in! hint hint ) if you have full advance key entry (so touch the door-handle to unlock not press the button on the fob) feature - as I'd like to compare that part no. with the one in my car - as it has keyless go, MMI touch/High etc.
    Any help greatly appreciated & thanks a million
  1. Traffic Sign Display missing
    By Evil Dan in forum Golf MK7 - 2013 - 2019
    Last Post: 11-09-2013, 11:52 AM
  2. Voice recognition issue
    By ttamlleb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-08-2013, 04:08 PM
  3. Passat SE Voice Recognition
    By laurona12 in forum In Car Entertainment
    Last Post: 16-07-2011, 10:33 AM
  4. Code Fault Recognition
    By csducks in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-01-2010, 10:10 PM
  5. Voice Recognition - No Function
    By Blackavant in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-04-2009, 03:09 PM
