Thread: Traffic sign recognition nearly coded
Page 21 of 22 FirstFirst ... 1119202122 LastLast
Results 201 to 210 of 217
  1. Re: Traffic sign recognition nearly coded
    Dec 2015
    Guildford
    Well done
    Sent from my CLT-L29 using Tapatalk
  2. Re: Traffic sign recognition nearly coded
    Mar 2019
    Rouen
    in my side i realize all the step with vcds, but no TSR in the ODB
    i understood that the step 5 is missing to put the parameter ZDC file in the calculator image processing 8E
    could you confirm to me the different product to buy
    - VCPSYSTEM &reg :: VCP CAN PROFESSIONAL :: vcpsystem - VCP CAN PROFESSIONAL SYSTEM manufacturer official shop 260€
    - download VCP 8.6
    - download zdc file a6_c7_imageProcessor_Camera_4g0907107d.zdc if the file is missing
    and normaly i can realize the step 5 ?
    Pierrotori
  3. Re: Traffic sign recognition nearly coded
    Mar 2019
    Rouen
    now it's good the zdc file is upload
  4. Re: Traffic sign recognition nearly coded
    Oct 2019
    WA, US
    Quote Originally Posted by watronik7 View Post
    OK guys. So far a lot of discussion about this topic but no results so it is time to reveal the secret. See my step by step guide here: Dropbox - Audi Traffic Sign Recognition Retrofit Guide rev1.pdf
    Rev 01 added today 24.08.2018
    Thank you very much for posting this!
    I have a 2012 A6 with ACC and had lane assist previously retrofitted and working.
    I'm in the US & I've gone through the guide and got VCP so I could perform parametarization using "USA_WITH_HEADING_CONTROL_WITH_TRAFFIC_SIGN" for my 8E - 4G0907107D. My Camera is 4H0907217A.
    I still keep getting "Currently Restricted", no other errors/faults & I've checked everything. Any ideas?
  5. Re: Traffic sign recognition nearly coded
    Dec 2015
    Guildford
    Hi. As I have mentioned in the guide there are areas where the system is not supported despite proper activation. I have read somewhere on the internet that some people in the US have experienced problems with this system. Unfortunately there is no official data describing where system should or should not work properly. If you have done everything as in my instruction I suggest you try to update your MMI and maps to the latest version and drive around to check if this problem refer to your particular location only. Ensure you have properly completed parametrization process as this is a key procedure to activate this system
  6. Traffic sign recognition nearly coded
    Jan 2018
    Mexborough
    26 Post(s)
    Can anyone offer pramatisization with VCP ? As a service or by remote?
  7. Re: Traffic sign recognition nearly coded
    Aug 2020
    romania
    hello can you please give me the zdc for 4G0907107C i dont have it in my vcp folder.
    thank you
  8. Re: Traffic sign recognition nearly coded
    Aug 2020
    romania
    Quote Originally Posted by alexzx View Post
    Hi guys, Watronik7 with your guide and VCP i activated TSR on my Audi A6 Avant 4G (2012)
    The file for 4G0907107C is available in VCP ;-)
    Thank you very much!!!
    Alessandro
    thank you
  9. Re: Traffic sign recognition nearly coded
    Dec 2008
    Hi, can someone help me out here, just followed all instructions to activate VZE on my A8 2013 , have all original installed, not retrofit, but cannot get this TSR working and getting showed on Drive assist,neither on HUD, NOWHERE, only in the MMI hidden settings, in the all related modules TSR is activated, reflashed zdc image processor with a6_imageProcessor_8e_4h0907107f,g.zdc, on the 8E module part no. is 4h0907107F, selected: with HC with TSR RoW option ,but the same ,no TSR menu, double checked every step 2-3 times. What am I missing, should I update MMI firmware to maki it work?
    Please any help is greatly appreciated.
    Regards
  10. Re: Traffic sign recognition nearly coded
    Nov 2020
    Dublin, Ireland
    I have an A6 C7.5 2015, imported from UK to Ireland:
    • ACC/LDW so all factory hardware should be installed
    • Did all the necessary adaptions in VCDS
    • Have not done imageprocessor firmware update
    • All UI options are turning up correctly
    • Getting the "outside operational area" probably after GPS is acquired
    My question are:
    • Is the current imageprocessor firmware likely just lacking TSR OR is it working fine but only works within the UK?
    • Can someone with UK TSR confirm if it works in Ireland or elsewhere in Europe which would mean I'm just missing TSR, or otherwise I would need RoW firmware instead of UK?
    I can't find info on C7 generation but C8s sold here can have TSR, so I'd assume it is possible. Just checking before I buy VCP.
  1. Traffic Sign Display missing
    By Evil Dan in forum Golf MK7 - 2013 - 2019
    Last Post: 11-09-2013, 11:52 AM
  2. Voice recognition issue
    By ttamlleb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-08-2013, 04:08 PM
  3. Passat SE Voice Recognition
    By laurona12 in forum In Car Entertainment
    Last Post: 16-07-2011, 10:33 AM
  4. Code Fault Recognition
    By csducks in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-01-2010, 10:10 PM
  5. Voice Recognition - No Function
    By Blackavant in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-04-2009, 03:09 PM
