Thread: damaged VACUUM BOOST CONTROL VALVE SOLENOID PIERBURG PA6-GF30.
  1. damaged VACUUM BOOST CONTROL VALVE SOLENOID PIERBURG PA6-GF30.
    Aug 2009
    sunderland
    hi
    i have a damaged VACUUM BOOST CONTROL VALVE SOLENOID PIERBURG PA6-GF30.
    one of the plastic nipples has snapped,it looks very close and mounted next to the other nipple.
    could i block off the snapped nipple and put a tee connector on the good nipple and run both rubber pipes off one nipple?
  2. Re: damaged VACUUM BOOST CONTROL VALVE SOLENOID PIERBURG PA6-GF30.
    Aug 2011
    Meath
    No you have to replace it, You could do a temporary repair with the broken piece and some epoxy putty like EP-200. It's a valve so it activates different pipes at different times. New is about £50.00 buy genuine!!!
    1 1 0
  3. Re: damaged VACUUM BOOST CONTROL VALVE SOLENOID PIERBURG PA6-GF30.
    Aug 2011
    Meath
  4. Re: damaged VACUUM BOOST CONTROL VALVE SOLENOID PIERBURG PA6-GF30.
    Aug 2009
    sunderland
    thanks for info...will buy one
  1. Boost Control Valve for Turbocharger
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-10-2010, 10:32 PM
  2. Help? Solenoid Boost Pressure Control (N75) Look Like ?
    By bowdley in forum VCDS - General Questions
    Last Post: 19-03-2009, 09:30 PM
  3. N75 Boost Control Valve
    By Passatguy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-02-2009, 08:16 PM
  4. Boost control valve
    By CherryB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-07-2008, 08:20 AM
  5. N75 - Boost Control Solenoid
    By twign in forum Golf MK4 - 1999 - 2004
    Last Post: 05-06-2008, 08:56 AM
