Thread: Some Fault Codes
  1. Some Fault Codes
    Dec 2013
    Milton Keynes
    Firstly, big thanks to Cockney Boy for the diagnostics, settled my mind that there wasn't anything unfixable (hopefully!).
    Here are the fault codes on my car, wondered if anyone had an idea of what they could be?
    Address 18: Aux. Heat Labels: None
    Part No SW: 4L0 910 105 HW: 4L0 815 071 D
    Component: Heizgeraet H08 0080
    Revision: 0000000C Serial number: 00000009014264
    Coding: 0000001
    Shop #: WSC 31414 790 00001
    VCID: E0C497123306111E743-80B5
    2 Faults Found:
    01413 - Dosing/Metering Pump (V54)
    007 - Short to Ground
    02251 - Heater Unit Locked
    000 - -
    Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
    Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
    Component: TSG FA H12 0150
    Revision: 00-00000
    Coding: 0019035
    VCID: 2F66A42EBE587E663D9-807A
    2 Faults Found:
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 122387 km
    Time Indication: 0
    Date: 2013.12.28
    Time: 11:06:09
    02126 - Central Locking Button; Exterior Door Handle
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 122387 km
    Time Indication: 0
    Date: 2013.12.28
    Time: 11:09:43
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
    Component: TUNER EU/US/RDW H42 0620
    Revision: 00000000 Serial number: 388G/077638155
    Coding: 0000001
    VCID: 2E58B92AB952776E36F-807B
    2 Faults Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 200
    Mileage: 113969 km
    Time Indication: 0
    Date: 2013.04.19
    Time: 09:57:13
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 166
    Reset counter: 200
    Mileage: 0 km
    Time Indication: 0
    Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
    Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
    Component: SDS 3502 UK H46 0630
    Revision: 00000000 Serial number: 00000707090096
    Shop #: WSC 12336 024 394758
    VCID: 3668914A41024FAE7EF-8063
    2 Faults Found:
    02095 - Component Protection Active
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 122387 km
    Time Indication: 0
    Date: 2013.12.28
    Time: 11:06:11
    02084 - Component Protection
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 0
    Time Indication: 1
    Address 6D: Trunk Elect. Labels: None
    Part No SW: 4L0 910 945 HW: 4L0 827 851 C
    Component: ValeoHeckdeckel H24 0290
    Revision: --H24001 Serial number: E5030000B
    Shop #: WSC 98765 666 38354
    VCID: ECDCF322CFCE457ED8B-80B9
    Subsystem 1 - Part No: 4L0 910 946
    Subsystem 2 - Serial number: E5030100B
    Subsystem 3 - Serial number: RD26.07.07--H24001001A0082ÿ
    Subsystem 4 - Serial number: 1A0082ÿ
    1 Fault Found:
    02242 - Rear Lid Lock Button in Luggage Compartment (E406)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 201
    Mileage: 115628 km
    Time Indication: 0
    Date: 2013.07.12
    Time: 20:35:38
    Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
    Component: TSG HR H21 0150
    Coding: 0018442
    VCID: 3162A256A86C68962BD-8064
    1 Fault Found:
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 122387 km
    Time Indication: 0
    Date: 2013.12.28
    Time: 11:06:09
    The advanced key we think will be sensors, however, drivers door, with the 2 faults, could that be control module?
    The tailgate works fine, so unknown issue.
    Radio also works fine.
    Cheers in advance
  2. Re: Some Fault Codes
    46 Post(s)
    Did he clear and rescan?
    Seeing faults from July and April.
  3. Re: Some Fault Codes
    Buckinghamshire
    The posted codes are after the DTC's were cleared.
  4. Re: Some Fault Codes
    46 Post(s)
  5. Re: Some Fault Codes
    Dec 2013
    Milton Keynes
    This isn't looking cheap....
  1. some fault codes
    By mgray167 in forum VCDS - Help Requests
    Last Post: 11-05-2011, 07:20 PM
  2. Please Help A3 Fault codes Radio Fault
    By MAFED in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-05-2010, 04:21 PM
  3. Fault codes
    By roboman-spain in forum Golf MK3 - 1993 - 1999
    Last Post: 16-07-2009, 02:23 PM
  4. What are these Fault codes?
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-03-2009, 10:16 PM
  5. Fault codes
    By andyd118 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-05-2007, 10:27 PM
