Thread: Shift Lock Solenoid Problems!
  1. Shift Lock Solenoid Problems!
    May 2013
    Atherton, England
    My A6 is apparently suffering problems with it's Shift Lock Solenoid which prevents the locking pin from releasing the gear shifter/lever when the brake pedal is pressed resulting in the car being stuck in park.
    I'm continually having to press the emergency release button under the ashtray to get things going again but it soon reverts back.
    My brake pedal switch is fine and the fault code mentions the solenoid.
    Is this a common problem with an easy fix?
  2. Shift Lock Solenoid Problems!
    46 Post(s)
    Common problem, do a search as I'm pretty sure it's been covered before.
    Post the fault code up too.
  3. Re: Shift Lock Solenoid Problems!
    May 2013
    Atherton, England
    At the moment I'm having to regularly press the emergency release button under the front ashtray.
    Booked in with VAG Bolton on 6th January for new solenoid.
  1. A3 auto brake lock solenoid electrics
    By Sly in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 11-03-2011, 12:16 PM
  2. Lock problems
    By doug.howsie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-10-2008, 11:18 PM
  3. Audi A6 auto shift lock
    By ate75 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-03-2008, 12:27 PM
  4. A4 door lock problems
    By A4 Driver in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-10-2007, 09:26 AM
