Thread: HDD Sat Nav constantly losing "Home" favourite
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. Re: HDD Sat Nav constantly losing "Home" favourite
    #21
    Wuffles Guest
    Quote Originally Posted by johnsimcox View Post
    KJsyt driven my car this time I remembered my phone and my Home Favourite reappeared. T think when you connect the phone it is overwriting the contacts (and favourites) with those from your phone, hence no Home on the phone (there's an ET gag there somewhere!!) hop Home Favourite. I presume if you try again without the phone connected that Home will reappear. Does Mrs W have a Home contact on her phone?
    Just checked, and yes she does - so that's that.
    [dramatic pause]
    Unfortunately, there's no address in that contact, so that's not that.
    Is yours fairly up to date software wise? This definitely wasn't a problem this extreme before the latest update in June of this year.
  2. Re: HDD Sat Nav constantly losing "Home" favourite
    #22
    Apr 2009
    Surrey
    182 Post(s)
    Quote Originally Posted by Wuffles View Post
    [dramatic pause]
    My car has not been to the dealer since I bought it in June 2012 so it does not have any software update (currently running P11474 and BT 3.22.6) I am thinking it may be that the lack of an address in Home on the phone is confusing it as it thinks I cannot have a Nav favourite if there is no address. My Home entry n my phone does have an address
  3. Re: HDD Sat Nav constantly losing "Home" favourite
    #23
    Wuffles Guest
    Red herring then, the software update I mean.
    I've never had a "home" in my phone though, and this wasn't a problem before. I'll try adding one in now (with an address) and see what happens. BBIAB.
  4. Re: HDD Sat Nav constantly losing "Home" favourite
    #24
    Wuffles Guest
    Right. Not that this is definitive at all of course. But this is what happened - Chris will be pleased he was right at the start.
    Added a Home to the phone's contacts, with address, made no odds. Still deleted the Home favourite in the car immediately upon BT transfer.
    Then aded the Home favourite to the car again after the BT handshake and it's remained after a couple of car reboots. Also, deleting the Home contact on the phone has not affected the car either. So it's not a requirement to have that? I don't know. Vague.
    No idea at all what will happen later once the Wife's been near it again and more importantly another iPhone has synced and left it's BT mess all over the place. I suspect the Home favourite will be no more.
    I'll get her to add it again herself later on and see if it survives a couple of syncs from both phones.
    Also, this would fit in with what I was saying about it not being as much of an issue before the software update. You can catch the Nav in a good mood if it's before the phone's started syncing but after the boot process of the Nav system. In that there is a window of opportunity to start a navigation to your Home favourite - think the boot must be slower since the updates and therefore the window is smaller.
    Science.
  5. Re: HDD Sat Nav constantly losing "Home" favourite
    #25
    Jul 2013
    Northampton
    I have the same problem. It's definitely dependant on whether you have your phone connected via Bluetooth. Once connected it comes up after about 30 secs.
    Doesn't do this on my wife's Q7...but is 12 months older & different software.
    Also, only last week, I took the car in complaining the screen had twice not come out from the dashboard on start up. They oiled the runners. It has not happened since, but was it a coincidence that the two times it happened were the coldest days this year since getting the car.
    purchased in Sept....A6 C7 S-Line Black Edition...don't know there is a common fault here.
    Tnx Birgy
    Audi A6 (C7) 3.0 BiTurbo Quattro S-Line Black Edition
    Tech Pack High, Memory Heated Package
  1. Replies: 4
    Last Post: 08-10-2015, 02:54 AM
  2. MMI 2g High - Odd Sat Nav Map "fault" - losing road display but navigation ok
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-05-2013, 07:20 PM
  3. Golf MK7 - Anyone "SEEN" the standard SAT NAV yet !!
    By JDB007 in forum Golf MK7 - 2013 - 2019
    Last Post: 22-12-2012, 11:28 AM
  4. Question A8 Sat Nav "reload DVD"
    By Gerbil in forum In Car Entertainment
    Last Post: 02-01-2009, 04:42 PM
  5. "CD-ROM read error" - Audi A4 Sat Nav Plus
    By teesah in forum In Car Entertainment
    Last Post: 11-08-2008, 11:21 PM
