Thread: Wind noise from drivers side
  1. Wind noise from drivers side
    Dec 2011
    leeds
    Hi All
    I notice recently there is a lot traffic noise when I am sat in the drivers seat and a draught as well. Can the door hinges/latch be adjusted to solve this? Looking at the car with doors closed the drivers side door is slightly out of line (down) compared to the rest of the panels. Easy fix? Can I adjust the door seals?
    Chatty
  2. Re: Wind noise from drivers side
    Feb 2009
    Glasgow UK
    Hi there, I had a similar issue, but without the wind noise or draught, so perhaps yours has gone further?
    I believe it may be the door hinges, I just replaced my drivers side on my A6......See thread below
    Drivers door dropping slightly
    Hope it helps
    Good luck
  3. Re: Wind noise from drivers side
    Dec 2011
    leeds
    Thanks JimC64 will check this out.
    Chatty
    Quote Originally Posted by JimC64 View Post
    Hope it helps
    Good luck
  4. Re: Wind noise from drivers side
    Dec 2011
    leeds
    Update on this - looking down the side of the car the top half of the door sticks out slightly whilst the bottom half is perfectly aligned to the bodywork. Can the top half be adjusted by moving the striker in/out slightly, I have noticed the striker is slightly off centre at the moment.
    Chatty
  5. Re: Wind noise from drivers side
    Feb 2009
    Glasgow UK
    Try opening your door just a little bit, then try to lift it and see if you get any movement?
    It may be that the top hinge has worn and needs replaced.
    I have came across more lower hinge issues it seems as there seems to be many for sale on the Bay, not so much with the top
    Getting back to the top hinge, there is a little grub screw ( underneath a plastic cap ) that can be screwed back in, perhaps with a little loctite but if thtas the issue its only a very temporary measure and will need replaced.
    Maybe others with either different experiences will chime in to help you get a fix.
    Good luck
  1. Weird noise from front drivers side wheel!!
    By cunny678 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-12-2018, 01:32 PM
  2. Drivers Door Wind Noise
    By dulux72 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-04-2012, 12:31 PM
  3. Wind Noise Drivers Window?
    By quattrodlo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-10-2011, 07:17 PM
  4. Question mk5 Golf wind noise - drivers side
    By petesaysblimey in forum Golf MK5 - 2004 - 2009
    Last Post: 03-09-2009, 09:26 AM
  5. Whistling noise through drivers side vent!
    By cbtg2006 in forum Bora - 1998 - 2005
    Last Post: 21-02-2008, 12:59 PM
