Thread: No oil level on MMI after oil change
  1. No oil level on MMI after oil change
    Jul 2011
    wirral
    Audi A4 B8 2009
    Just completed my 1st oil/oil filter change after 10K of driving since owning the car. The MMI display was showing close to the min level mark
    Syphoned out 3 litres, and poured back in 4.5 litres and still nothing is showing on the display with regards to min/max
    I now have no idea how much oil is in there, but have no warning lights saying its to low or too high.
    Any ideas ?, doesn't anything need to be reset ?
    cheers
  2. Re: No oil level on MMI after oil change
    Jul 2011
    wirral
    OK - ignore the above. Took it for a spin and its now showing up as mid level. VCDS shows the level as 77mm, 34 mm is the min level
  3. Re: No oil level on MMI after oil change
    46 Post(s)
    Fit a proper dipstick, theres a retrofit kit for it.
    Been covered a couple of times on here so search for 'dipstick retrofit'.
  1. MMI oil level check ???
    By s7gpt in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-05-2013, 08:21 AM
  2. Oil Min Light Error - Oil Level Sensor Fault (2006 2.0l TDi S-Line)
    By i_786_i in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2012, 11:24 AM
  3. Oil level warning light on BUT oil level is correct!
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 02-08-2011, 07:44 PM
  4. Question Audi A4 MMI Oil Level Display Problem
    By DougC in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-01-2010, 07:13 PM
  5. Question A4 B8 Problem of Oil Level Display in MMI
    By nordi33 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-02-2009, 12:30 PM
