Thread: Changing The Rear Light Bulbs!!
  1. Changing The Rear Light Bulbs!!
    Sep 2007
    Bulbs don't seem to last long in these vehicles do they?? However, I had no problem in changing bulbs in the offside rear cluster recently. Pulled red tab, remove locating screw etc...
    Now two bulbs need replacing in the near side rear cluster, but when I remove the cover, there is no red tab to pull!!!
    Any suggestions on the best way to remove this without having to take the whole lining out?
    Many thanks in advance....
  2. Re: Changing The Rear Light Bulbs!!
    Sep 2007
    Its a 2002 A4 model by the way...Thanks
  3. Re: Changing The Rear Light Bulbs!!
    notts
    i thought the red tab was to release the fuel flap in emergency?
    you only need to remove the screw then pull out the rear cluster
  4. Re: Changing The Rear Light Bulbs!!
    Dec 2006
    RED TAB....!!
    Dont pull that.. its for the lock on the fuel cap cover... (you may find it will not lock now??)
    See the guide i posted in the B6 section of this forum for changing bulbs.
    https://www.vwaudiforum.co.uk/forum/s...ead.php?t=7485
    RickT
  5. Re: Changing The Rear Light Bulbs!!
    Sep 2007
    Phewww!!
    Glad I checked hear first, all sorted thanks all!
  1. audi A4 - changing indicator bulbs - HELP
    By moody in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-10-2014, 11:02 AM
  2. changing the bulbs on a mk4 golf
    By eghuws in forum Golf MK4 - 1999 - 2004
    Last Post: 04-07-2007, 02:28 PM
  3. Changing Rear brake light bulb
    By jon123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2007, 09:48 AM
  4. changing bulbs
    By jack71 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-06-2007, 02:36 PM
  5. Changing headlamp bulbs in 04 Passat TDI
    By srobins in forum Passat - Archive Topics
    Last Post: 12-01-2007, 02:47 PM
