Thread: Australian VW Polo 2003 EPC light problem
  1. Australian VW Polo 2003 EPC light problem
    Aug 2011
    NSW Australia
    The light comes on when accelerating away from low speeds and from accelerating from a constant steady speed. Sometimes it will go into limp mode at the same time.
    I’ve read the ECU with VAG.com and after much searching online and many hours looking under the bonnet for possible reasons and find nothing, I think that maybe I should ask for some other input.
    Here are the results of the ECU. I am wondering what you guys would suggest for possible fixes?
    Chassis Type: 9N - VW Polo
    Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ4U009934 Mileage: 157470km/97847miles
    Address 01: Engine Labels: 036-906-034-APE.lbl
    Part No: 036 906 034 FJ
    Component: MARELLI 4MV 4830
    Coding: 00071
    Shop #: WSC 20065
    VCID: 5FC79D38DD3DB6E078F
    WVWZZZ9NZ4U009934 VWZ7Z0C8097164
    3 Faults Found:
    17961 - Barometric / Manifold Pressure Signals
    P1553 - 35-10 - Implausible Correlation - Intermittent
    17912 - Intake Air System
    P1504 - 35-10 - Leak Detected - Intermittent
    17550 - Load Calculation Cross Check
    P1142 - 35-10 - Lower Limit Exceeded - Intermittent
    Readiness: 0000 0101
  2. Re: Australian VW Polo 2003 EPC light problem
    7 Post(s)
    I'd would all of the inlet tract for leaks letting un-metered air in and also check any vacuum hoses and or plastic t pieces, elbows etc.
  3. Re: Australian VW Polo 2003 EPC light problem
    Aug 2011
    NSW Australia
    I've had similar response from my local VW dealer, they want to take the inlet manifold off to check the seals. No guarantee, just a big quote. Is there anyway to be sure about this without exploratory surgery? In my experience exploratory surgery leads to further complications! I've also had another Euro garage tell me that the throttle body needed replacement.
  4. Re: Australian VW Polo 2003 EPC light problem
    7 Post(s)
    Just read my 1st response and it makes no sense!
    It should have read, "I would check....."
    What engine is it? 1.2, 1.4 ?
  5. Re: Australian VW Polo 2003 EPC light problem
    Aug 2011
    NSW Australia
    OK thanks, that makes a little more sense. Engine is BBY 1.4l petrol.
  6. Re: Australian VW Polo 2003 EPC light problem
    Aug 2011
    NSW Australia
    After removing and disassembling inlet manifold, and removing EGR valve, I found no evidence of air leaks but did find large amounts of carbon build up in throttle body and adaptor plate to the point were the EGR port was blocked completely and the throttle body butterfly would have been partially blocked. cleaned all parts, reassembled and adapted TB and EGR. Tested all OK except now at steady speeds (60kmh) car is hesitating sharply (like as though accelerator pedal is being pushed up and down rapidly) No error codes have been generated on short runs so further testing is required.
    After reading other forums I came across an article regarding oil filler cap being removed and causing EPC error. I checked mine and found the filler adaptor neck was damaged and loose so have removed it and just put the cap direct to the engine. Tested removal while engine running and found that cap is needed to be sealed or EPC light will be generated. So I am now thinking the air leak errors were being created by the oil filler extension neck leaking.
  1. Please Help 2004 Polo 1.9 TDI Sport (100PS) EPC light on
    By deezlesrme in forum Polo - Derby - Lupo - Fox
    Last Post: 13-10-2012, 02:09 PM
  2. Please Help Polo 1.8 GTI - EPC light/Loss of power - With Code
    By mikeyh_wales in forum Polo - Derby - Lupo - Fox
    Last Post: 22-07-2012, 07:55 PM
  3. Polo 1.4 16V - EPC light, oil and service light issues
    By Trinster in forum Polo - Derby - Lupo - Fox
    Last Post: 19-08-2011, 08:57 PM
  4. EPC and Engine Light Fault 2003 Polo 16v
    By iggy28 in forum Polo - Derby - Lupo - Fox
    Last Post: 06-03-2008, 03:22 PM
  5. EPC light problem
    By bromulus2002 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-03-2007, 06:09 PM
