Thread: EPC Light - N276 Valve - Scan results...
  1. EPC Light - N276 Valve - Scan results...
    Sep 2013
    Under the bonnet
    Hi guys, got the EPC light showing on my car.. Its a 55 plate A3 1.6 FSI. I did a scan with VCDS and here are the results.
    2 Faults Found:
    008852 - Fuel Pressure Regulator Valve (N276)
    P2294 - 004 - Open Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 0
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 264034 km
    Time Indication: 0
    Date: 2013.12.11
    Time: 13:08:53
    Freeze Frame:
    RPM: 720 /min
    Load: 25.1 %
    Speed: 0.0 km/h
    Temperature: 52.0°C
    001056 - Catalyst System; Bank 1
    P0420 - 002 - Efficiency Below Threshold
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 264049 km
    Time Indication: 0
    Date: 2013.12.12
    Time: 14:57:16
    Freeze Frame:
    RPM: 1880 /min
    Load: 56.8 %
    Speed: 67.0 km/h
    Temperature: 83.0°C
    Readiness: 0000 0001
    Now i know i have 2 faults...Please do correct me if i need correcting from this point foward! The second fault i believe is because the CAT may be on its way out?
    The main issue i have is the EPC.. That fault has come up and from reading i think i need a new Fuel pressure regulator valve. How many BAR is the standard one? 3 or 4.. (my car is the 1.6 FSI)
    If it is 3 BAR, would this be the correct part? FUEL PRESSURE REGULATOR AUDI A3 A4 A6 80 90 100 1.6 1.8 2.0 TT 1.8T TURBO 3 BAR | eBay
    And is it possible to fit these yourself? If not what sort of labour costs should i be looking at?
    Thanks guys
  2. Re: EPC Light - N276 Valve - Scan results...
    46 Post(s)
    1 1 0
  3. Re: EPC Light - N276 Valve - Scan results...
    Sep 2013
    Under the bonnet
    Thanks for the reply Chris.
    I went and showed the scan results and the following part to my mechanic (http://www.ebay.co.uk/itm/FUEL-PRESS...90809119693%26)
    He asked if the regulator should be an electrical one and not mechanical as the scan shows 'Open circuit'. Im not sure if that is the correct part or not, please can someone clarify?
  4. Re: EPC Light - N276 Valve - Scan results...
    Sep 2013
    Under the bonnet
    Despite the lack of replies, i lcated the HPFP and there is a crack on the black part of it however after removing wires, cleaning the EPC fault has gone and same with the CAT. not bad..
  1. Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
    By slingshot1801 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-04-2013, 12:00 PM
  2. Full scan results
    By PETER G in forum VCDS - Help Requests
    Last Post: 01-01-2012, 06:04 PM
  3. Audi A6 VagCom Scan Results.
    By cwilding in forum VCDS - Help Requests
    Last Post: 19-11-2010, 10:19 PM
  4. Lights on dash, post scan results
    By Drac in forum VCDS - General Questions
    Last Post: 18-04-2009, 08:36 PM
  5. Scan Results
    By kite in forum VCDS - General Questions
    Last Post: 18-03-2009, 07:54 PM
