Thread: Battery drain 0.68 amps and VCDS lite codes / faults
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Battery drain 0.68 amps and VCDS lite codes / faults
    Apr 2013
    Inverness, Scotland
    Hi All,
    Flat battery after few days of non use.
    Have connected multi meter in circuit to battery neg cable and neg post and is registering a 0.68 amp drain.
    Have scanned with VCDS lite and its detected these 2 faults:
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Controller: 8E0 820 043 AC
    Component: A4 Klimaautomat 1450
    Coding: 00000
    Shop #: WSC 00665
    VCID: 62B788C7FD57
    2 Faults Found:
    00716 - Air recirculation Flap Positioning Motor (V113)
    41-00 - Blocked or No Voltage
    00819 - High Pressure Sensor (G65)
    07-10 - Signal too Low - Intermittent
    would either of these faults cause a parasitic drain on battery?
    I was going to keep m/meter connected and start pulling fuses to see if drain dropped but fuse box is at lower side of dash so would have to keep door open and unsure if that would cause more current to drain and register on meter or maybe blow it (10 amp max).
    Any advice how to progress and pinpoint drain?
    Thanks in advance.
  2. Re: Battery drain 0.68 amps and VCDS lite codes / faults
    Jul 2011
    Norway
    I dont think those faultcodes are related to your problem. Start pulling fuses one by one to locate the right circuit
  3. Re: Battery drain 0.68 amps and VCDS lite codes / faults
    Apr 2013
    Inverness, Scotland
    yes i was thinking about doing that but unsure as would have to have front drivers door open to access fuse box and dont know if that would use more current and increase drain or blow my m/meter which has 10 amp maximum.
    Any ideas if this would increase the drain / amps?
  4. Re: Battery drain 0.68 amps and VCDS lite codes / faults
    Jan 2010
    southport
    Have you fitted any silly LED bulbs...
    I fitted LED side lights.Every day may battery was flat.Loads of testing everything.I just walk towards the front of the car,i could see a dim light on one side of the side lights.I Got Ridd.No problems since.
    Just a thought.
    2000 2.5TDI Quattro 173,000miles, just run in...Sold
    2006 TT 3.2 Quattro 40,000miles
    2005 A6 Avant 3.0TDI Quattro
  5. Re: Battery drain 0.68 amps and VCDS lite codes / faults
    Apr 2013
    Inverness, Scotland
    Quote Originally Posted by HAWKS View Post
    Just a thought.
    No mate i haven't its all stock standard lights, only thing that's been added, by last owner, was a Parrot hands free device through Radio but will be removing it shortly once my radio removal keys come in post.
  6. Re: Battery drain 0.68 amps and VCDS lite codes / faults
    Colchester,Essex
    Connect your multimeter again and pull the fueses 1 by 1 and watch when the power drain dropes,a lot of times its the radio.Also make sure you boot and glove box lights switch off.
  7. Re: Battery drain 0.68 amps and VCDS lite codes / faults
    Apr 2013
    Inverness, Scotland
    Quote Originally Posted by turpal View Post
    My only concern is that to gain access to fuse box i must leave the drivers door open, i suspect that this act will change the readings on my m/meter as central locking / convenience module will activate systems, such as door / interior light circuits, central locking etc and give me false readings and at worst overload my m/meter which is limited at 10 amps.
    Any knowledge on these systems would be appreciated.
  8. Re: Battery drain 0.68 amps and VCDS lite codes / faults
    Colchester,Essex
    Quote Originally Posted by ianianpb View Post
    I don`t know what your car is but if there is no switch on the pillar that its in the lock so just click the door lock twice so the system reads locked
  9. Re: Battery drain 0.68 amps and VCDS lite codes / faults
    Apr 2013
    Inverness, Scotland
    Car is A4 b6 1.9tdi quattro sport 2003.
    Will give it a try today see what happens.
  10. Re: Battery drain 0.68 amps and VCDS lite codes / faults
    May 2008
    Newbury
    How long did you keep the multimeter in circuit for? Bear in mind that some bits of the system only go to sleep after the car has been locked up for a while. Also, the fault codes you list can often mean the stepper motors for the control flaps will keep trying to operate for a few minutes (if you sit in the car when you have turned off the ignition you will hear them behind the dashboard) so you could have been measuring that.....
  1. advice on buying VCDS/VCDS-lite
    By borakev in forum VCDS - General Questions
    Last Post: 16-04-2019, 05:20 PM
  2. vcds lite
    By bobfish45 in forum VCDS - General Questions
    Last Post: 27-10-2013, 07:44 AM
  3. VCDS lite
    By ghostlymoron in forum Polo - Derby - Lupo - Fox
    Last Post: 10-10-2013, 01:14 PM
  4. vcds lite
    By jas828 in forum VCDS - General Questions
    Last Post: 01-03-2013, 01:28 PM
  5. VCDS-Lite
    By Rhys0_0 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 26-10-2011, 10:17 AM
