Possible Symptoms
Headlight Adjustment disabled
Malfunction Indicator Light (MIL) active
Possible Causes
Headlight Adjustment not performed
Aftermarket Suspension installed (i.e. lowered Suspension)
Level Sensor Readings out of Range
Level Sensor(s) faulty
Level Sensor Mounting damaged/faulty
Possible Solutions
Perform Headlight Adjustment
See Vehicle specific Diagnostic Procedures for Details
Check Level Sensors
Check Level Sensor Mounting
Special Notes
If Headlight Adjustment (Basic Setting) fails, check Level Sensors.
Check Measuring Value Blocks (MVB) if Level Sensor Readings within Specification.
When stored in combination with 01537, fix that one first.
There have been reports of lowered vehicles displaying an error message in Basic Settings due to incorrect level sensor readings. If the vehicle height sensor(s) are bottomed out, it may be necessary to modify the sensor bracket to allow normal adjustment to occur. Check to make sure that the sensor arms do not have their pivots facing the wrong direction as shown in this Mk5 platform VW thread: [VW Vortex]
