Thread: Mount solenoid valve
  1. Mount solenoid valve
    Dec 2013
    United Kingdom
    Hello,
    A few months ago, I was on a bypass, accelerated in fifth gear and suddenly lost power. I was driving at 50 miles per hour! I stopped and started the engine again. It went well for a while and suddenly lost power again. I took it to a garage and the error message was "mount solenoid valve" (sorry I don't have the error message number). They told me I had to change the turbo.
    I had the whole distribution changed in September (can belt, etc...) and it seemed to have stopped doing it.
    However yesterday it started again. It happens only when I floor it in fifth gear to go to sixth gear. Would that be really a turbo fault? It's an A4 1.9 TDI 52 reg.
    Changing the turbo costs a fortune and I don't want to get ripped off if it's something to do with another fault!
    Could someone help please?
    Thank you!!!
  2. Re: Mount solenoid valve
    Oct 2005
    Welcome to VWAF
    The garage who carried out the previous work should have provided a warranty.
    Take the car back to them, get it scanned for faults and then post them here.
  3. Re: Mount solenoid valve
    Aug 2011
    Meath
    Engine mounts can throw a fault code but they're basically harmless and changing the turbo will have no effect. There is a boost control valve that fails putting the car into limp mode a new one costs 50.00 ish. You need a scan first use a VAG indie or a dealer
  4. Re: Mount solenoid valve
    Oct 2013
    belfast
    17994- engine mount solenoid valve / N144- short to plus / P1586 intermittent if its something like one of your engine mounts are away. theres a sensor on one of them this can also be at fault. when your driving at some stage does the car feel like a wheels lose a sorta wobble movment. ive the same problem and its my engine mount away with it.
  5. Re: Mount solenoid valve
    Sep 2008
    chester
    17 Post(s)
    Very likely your turbo is over boosting and going into limp mode,I would get a scan done with someone with a vag scanner,if it is it will need removing and cleaning,the engine mount one is very common and not the cause. ps just read doctle has suggested it.
    1 1 0
  6. Re: Mount solenoid valve
    Aug 2011
    Meath
    Maybe try a different mechanic too. Hit and miss engines and engineering were never a hit
    Quote Originally Posted by nevo View Post
  1. Replies: 2
    Last Post: 23-05-2017, 09:26 PM
  2. Question Engine mount solenoid code 17996
    By allymac in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-05-2017, 08:00 PM
  3. 17994 - Engine Mount Solenoid Valves (N144/N145)
    By Adman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-02-2013, 12:10 AM
  4. engine mount solenoid valves
    By kangtdi in forum VCDS - General Questions
    Last Post: 09-12-2009, 05:20 AM
  5. engine mount solenoid nalve
    By coupe2 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-09-2008, 07:25 AM
