Thread: disable headlight washers
Results 1 to 9 of 9
  1. disable headlight washers
    Jan 2013
    Scotland
    11 Post(s)
    Ideally I would just ramp the freq right down, but cant see how that would be done, but if im correct with my thoughts, it looks like i could just untick the following to disablethem completely? im going through about a gallon of washer a day and i notice they engage far to often for my liking!1.jpg
    Audi A6 3.0 BiTDI Black Edition
  2. Re: disable headlight washers
    46 Post(s)
    Disable headlamp washer
    Y u no search?
  3. Re: disable headlight washers
    Jan 2013
    Scotland
    11 Post(s)
    lol, ive even got a post in that thread!! lol... so looks like my screen shot will indeed disable them as i imagine then.
  4. Re: disable headlight washers
    Sep 2008
    Berkshire
    Quote Originally Posted by gdallas View Post
    Don't forget to enable them again for any forthcoming MOT. If you have both washers and xenons fitted, then they must work in order to pass the MOT.
    A5 (Cabriolet) 2.0 TDI 177PS S-Line - Scuba blue, Technology pack (high), B&O soundsystem, Bluetooth (low), Heated seats, Autoglym life shine.
  5. Re: disable headlight washers
    Feb 2013
    Gloucester
    57 Post(s)
    Or, leave them active but change how often they jet the lights?
  6. Re: disable headlight washers
    Feb 2013
    Gloucester
    57 Post(s)
    Sorry, just seen you said you don't know how to do that. I can't remember off the top of my head but it is possible, I've got the coding at home to adjust the frequency of the wash and can't post it up when I'm home if you like? Or a quick google will tell you how
  7. Re: disable headlight washers
    46 Post(s)
    You'll disable them then complain when they're dirty when you need them most!
    Interesting VAG-COM codes for Audi A5/A4 B8/Q5, many for A6/A8/Q7 as well (by LoCal) - Audi A6 Q7 A8 A4 A5 Retrofit Jälkiasennus Nachrüsten Retro-fit
    Adjusting window/headlight washers and wipers: According to unconfirmed posts at motor-talk.de (see the original posts here for accurate information, in case my translation is flawed, Codierungen hier sammeln? Seite 58 : Sowas passiert nicht. and Codierungen hier sammeln? Seite 57 : Interesse besteht auf jeden fall... nur weiß ich nicht wie das...) in module Central Elect., adaptation channel 6 one can change the duration which the washers run, channel 25 the time of holding down the washer lever after which headlight washers activate and in channel 26 the amount of washer lever presses required to activate the headlight washers. According to these unconfirmed posts, to completely disable the headlight washers, change in module 09, coding, byte 20 from 04 to 00 and save. To disable the "one more wipe after some time" function in the window washer (Codierungen hier sammeln? Seite 56 : Das kommt wohl einfach auf die Wunschhöhe an. Der Spiegel kenn...), in module 09, coding, wiper control sub-module (WWS), long coding wizard, change byte 1, bit 3. There is also talk of disabling the rear wiper, perhaps a coding checkbox already in Central Elect. module in VAG-COM/VCDS (see below). Some of these changes may not work in all model-years and are unconfirmed.
    Or
    Set Headlight washer - Duration
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 6
    change to e.g. 500
    ________________________________________
    Set Headlight washer - Cycles
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 26
    change to e.g. 10
  8. Re: disable headlight washers
    Feb 2013
    Gloucester
    57 Post(s)
    ^^ yeah something like that lol
  9. Re: disable headlight washers
    Jan 2013
    Scotland
    11 Post(s)
    ha,,, sorry for the delay lads... i disabled them, but might try the coding you guys posted.. thanks for the heads up.
  1. Question Headlight Washers
    By acmo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-01-2012, 06:36 PM
  2. Question Headlight washers
    By macman1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-10-2011, 09:20 PM
  3. Please Help Headlight washers
    By mermio in forum Golf MK5 - 2004 - 2009
    Last Post: 29-12-2009, 12:01 PM
  4. headlight washers
    By aaman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-07-2009, 01:14 PM
  5. Headlight Washers
    By malaroo978 in forum VCDS - Help Requests
    Last Post: 02-06-2009, 07:10 PM
