Thread: Audi A3 2.0 tdi sport 2003 cut out
  1. Question Audi A3 2.0 tdi sport 2003 cut out
    Jul 2007
    I have an Audi A3 2.0 tdi sport 2003.
    The car keeps cutting out and it happens sporadically where the car completely loses power and electrics and you have to pull over to turn off and restart.
    This does not seem to be reproduceable and it has been taken into an Audi dealer who cannot find the fault.
    This happens at both high and low speed and also wet and dry weather.
    Can someone please help me out as I do not know what to do.
  2. Re: Audi A3 2.0 tdi sport 2003 cut out
    135 Post(s)
    2040 Post(s)
    When you say completely loses electrics do you mean everything, lights, wipers, radio, heater blower etc? Can you send me your chassis number by PM?
  3. Re: Audi A3 2.0 tdi sport 2003 cut out
    Jul 2007
    I cannot send PM's.
    The problem occurs more when driving harder and when going uphill but not all the time.
    The eletrics all work though so it is only a engine cut out problem.
    To reset it, whilst going a long, I just switch off the engine (with the key in the ignition) and switch back on and the problem is resolved. Not much fun though on the outside lane of the M25!
  4. Re: Audi A3 2.0 tdi sport 2003 cut out
    135 Post(s)
    2040 Post(s)
    I would change the ECU relay first.
  5. Re: Audi A3 2.0 tdi sport 2003 cut out
    May 2007
    knee deep in clunge
    14 Post(s)
    engine speed sender is suspect(crank)and doesnt store a fault as it restarts and the sporadic fault code is lost.
  6. Re: Audi A3 2.0 tdi sport 2003 cut out
    May 2007
    knee deep in clunge
    14 Post(s)
    Also Check For Oil Deposits In The Fuel Filter As Oil Can Mix From The Tandem Pump And O Ring Causing The Contamination
  7. Re: Audi A3 2.0 tdi sport 2003 cut out
    Jul 2007
    Thats great thanks for all the help.
    I will try and get back to you both.
    Once again thanks for the help!
  1. audi diagnostics plug on Audi A3 2003 -
    By alistairr24 in forum Audi A3 - Archive Topics
    Last Post: 30-08-2007, 06:45 PM
  2. Audi A2 2003 1.4
    By audia2 in forum A2
    Last Post: 29-07-2007, 10:21 PM
  3. 2003 PASSAT 130 BHP ESTATE SPORT
    By DAZKIM in forum Passat - Archive Topics
    Last Post: 15-08-2006, 06:08 PM
  4. 2003 PASSAT 130 SPORT
    By ALED O in forum Chat - Completely Off Topic
    Last Post: 13-03-2006, 10:02 PM
