Thread: Full legal copy of vcds Oxford,
Results 1 to 10 of 11
  1. Full legal copy of vcds Oxford,
    Jan 2009
    Not a lot of experience but always willing to take a look and see if I can help.
  2. Re: Full legal copy of vcds Oxford,
    Feb 2014
    London, UK
    Any chance of some help tomorrow (Friday) either lunchtime if you're not too far from Cowley, or early evening?
    Thank,
    Mark
  3. Re: Full legal copy of vcds Oxford,
    Jan 2009
    Hi Mark, Can't do Friday as I'm away from Oxford at the weekends. Could do Monday or Tuesday night. What's the problem? is the vehicle driveable?
  4. Re: Full legal copy of vcds Oxford,
    Feb 2014
    London, UK
    Thanks for the response. I'm only in Oxford 2 days a week and next week I have to rush off after work both days.
    The problem is with the central locking - the boot and fuel filler flap locks don't work. The vehicle is driveable.
  5. Re: Full legal copy of vcds Oxford,
    Jul 2014
    Oxford
    Any chance of some help coding for a retrofitted Cruse Control to my 2007 S4 Avant. The unit is fitted but I don't have VAG-COM or or VCDS.
    I live in central Oxford.
  6. Re: Full legal copy of vcds Oxford,
    Jan 2009
    Quote Originally Posted by dermotdm View Post
    I can do one evening next week. I'm in Cuttslowe, whereabouts are you? I've no experience of coding a cruise control though.
  7. Re: Full legal copy of vcds Oxford,
    Jul 2014
    Oxford
    Cheers,
    Next Mon or Tues would be perfect. I am in Central Oxford (Longwall)
  8. Re: Full legal copy of vcds Oxford,
    46 Post(s)
    Cheers,
    Did you add the additional wire which may be needed and check your steering ecu version is compatible?
    Cruise Control Retrofitting (8E) - Ross-Tech Wiki
  9. Re: Full legal copy of vcds Oxford,
    Jul 2014
    Oxford
    Cheers Chris, I think hardware side is OK. The car has 3 spoke multifunction wheel but from what I have read we need to tell VCDS we have fitted cruise.
    Can we check ECU with VCDS.
    Would you like to email me offline regarding meeting up etc
    Dermot
    <dermot.ohare@chem.ox.ac.uk>
  10. Re: Full legal copy of vcds Oxford,
    Oct 2014
    Surrey
    hi there...
    Any chance of some vcds coding help?
    i have an RNS510 navigation headunit and just had an aftermarket sub and amplifier installed to it. I need to code it to output a flat EQ as suggested is possible here:
    Volkswagen RNS 510 coding when installing with a factory amplifier | my-gti.com the byte 5 bit in particular is pretty much all i'm looking to do.
    The car is a 2010 Passat CC
    I'll be in oxford on Monday (17/10/2014) if that isn't too short notice? or could arrange for some other date/time
    cheers
  1. Replies: 10
    Last Post: 04-11-2013, 12:26 PM
  2. Full vcds available in Fareham
    By TH Performance in forum VCDS - Users Locations
    Last Post: 31-07-2013, 12:41 PM
  3. Full Hex-Can VCDS Kingston upon Thames
    By quattromark in forum VCDS - Users Locations
    Last Post: 12-03-2012, 07:58 PM
  4. Replies: 3
    Last Post: 14-02-2012, 08:33 AM
  5. Your Legal Rights - All matters Legal and Associated
    By auiron in forum Chat - Completely Off Topic
    Last Post: 29-01-2007, 06:58 PM
