Thread: Abs Ecu Removal A6
Results 1 to 8 of 8
  1. Abs Ecu Removal A6
    DAH Guest
    Hi I've got a problem with the ABS ECU on an A6 2.5TDI 1999 AVANT. Need to remove the electronics end of the unit, which appears to be held on with six screws. Any advice would be welcome?
  2. Re: Abs Ecu Removal A6
    7 Post(s)
    What leads you to think there is something wrong with it ?
    Most abs probelms are wheel sensor related. Have you had it scanned for faults ?
  3. Re: Abs Ecu Removal A6
    May 2007
    knee deep in clunge
    14 Post(s)
    If you are going to split it take the unit off complete and then seperate the ecu from the solonoid block,be caefull to line it up when inserting new ecu.
  4. Re: Abs Ecu Removal A6
    131 Post(s)
    1976 Post(s)
    Are you going to fit the repair set?
  5. Re: Abs Ecu Removal A6
    DAH Guest
    Quote Originally Posted by BigCol View Post
    Dealer diagnosed the control unit as faulty, quote"tried to interrogate abs fault and memory - unable to connect, checked connections going to abs control - all fine. control unit faulty." Thet've quoted £1,000 for a replacement!
  6. Re: Abs Ecu Removal A6
    DAH Guest
    Thanks for the tip.
  7. Re: Abs Ecu Removal A6
    May 2007
    knee deep in clunge
    14 Post(s)
    This quite common on early models
  8. Re: Abs Ecu Removal A6
    131 Post(s)
    1976 Post(s)
    The repair kit is less than £500.
  1. Ecu removal help ?
    By philglasgow in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-08-2007, 10:07 AM
  2. Diesel Cat Removal
    By t0m541 in forum Audi A3 - Archive Topics
    Last Post: 20-06-2007, 01:03 AM
  3. Bumper Removal
    By RonJon85 in forum Polo - Derby - Lupo - Fox
    Last Post: 19-05-2007, 06:46 PM
  4. A4 wiper arm removal
    By paul46 in forum Audi A4 - Archive Topics
    Last Post: 02-04-2007, 11:59 PM
  5. Removal of old car kit
    By Chazzy in forum Passat - Archive Topics
    Last Post: 16-10-2006, 07:38 PM
