Thread: 1999 Polo 1.6 Auto AEE code
  1. 1999 Polo 1.6 Auto AEE code
    Jul 2007
    I can't seem to get the timing to line up on my Polo. The manual says 6 Degrees but the distributor runs out of travel before it reaches 6 Degrees. Does this mean that the distributor is going home? The car is having a few starting problems but once its running it seems mostly ok but then misfires for a bit. Any info greatly accepted.
  2. Re: 1999 Polo 1.6 Auto AEE code
    Jul 2007
    Thought that there was a possibility of the valve timing being a tooth out but rechecked it today and valve timing is spot on, not only that but it runs so well anyway that it could have not been a tooth out. Still stumped why the distributor should be so hard over to try to get the correct timing setting. Where is No1 supposed to be on the dissy cap?
  1. Question mk 3 golf aee code won't start
    By neo5 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-09-2022, 06:09 PM
  2. Fault Code Read Needed - Golf Mk3 1.6 AEE
    By SammoVWT in forum VCDS - Users Locations
    Last Post: 05-03-2010, 09:53 AM
  3. Offered - Engine Code AEE
    By jeff_smart in forum Golf MK3 - 1993 - 1999
    Last Post: 26-08-2009, 01:11 PM
  4. Polo 1.6 AEE Throttle Body
    By twign in forum Polo - Derby - Lupo - Fox
    Last Post: 18-05-2008, 03:29 PM
  5. Where is idle control valve on AEE Engine code??? URGENT!
    By cara_essex in forum Golf MK3 - 1993 - 1999
    Last Post: 27-03-2008, 03:09 AM
