Thread: stop start system fault.
Results 1 to 8 of 8
  1. stop start system fault.
    Nov 2013
    United Kingdom
    Hello everyone.
    I have just purchased my Passat 1.6 blue motion diesel on a 59 plate. I have a question about a possible problem I might be having?
    I keep getting a message flash up that says system fault stop start - it has a picture with it - looks maybe like a electricity symbol with a line through it.
    Is this a normal generic message showing that not all the criteria for the stop start system has been met, so it can't do it? Or is this indicating a fault?
    The actual system has worked on the car. But the other day I went a reasonable journey to Birmingham and back and it didn't work once (temp was under 4degrees)
    Anybody able to help me out at all?
    Thanks!
    Marc
  2. Re: stop start system fault.
    46 Post(s)
    Sounds like a fault, best getting it scanned or take it back to the dealer (assuming you bought it trade).
    Could you post a picture?
    Welcome to VWAF.
  3. Re: stop start system fault.
    Nov 2013
    United Kingdom
    Ah I thought so. Thanks for the quick reply.
    Yeah I got it trade. So will give them a call. I will grab a picture later and post it (will be after 5 though stuck at work until then)
    Thanks again.
    Marc
  4. Re: stop start system fault.
    Nov 2013
    United Kingdom
    I have got a couple of pictures of the error message as requested. I just wondered if anyone else has seen/gets this message?
    Thanks.
    Marc
    *Edit* The first attachment shows the error symbol in the top right hand corner of the display. The second photo is the main error message that pops up.
  5. Re: stop start system fault.
    Norfolk
    I doubt you will get much help outside of a dealer. VW have released almost no information about this system which makes it hard to advise remotely.
  6. Re: stop start system fault.
    DSG4ME Guest
    Needs a code read really or it's simply a guess,
    If the ABS is part of it hope it's cheap sensor.
  7. Re: stop start system fault.
    Nov 2013
    United Kingdom
    Ok. Thanks for the replys. Its appreciated. The cars going back to the dealer I purchased it from on Friday so will see what they say. Whatever it is I'm not paying as I've only had the car 7 days from them and its been doing it since I picked it up!
    Will update with what they claim the problem is!
  8. Re: stop start system fault.
    vespa Guest
    Quote Originally Posted by marcosborne View Post
    They will have to fix it FOC
  1. Stop start system behaviour
    By markp306 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 13-09-2013, 10:16 PM
  2. Stop Start Fault
    By MFGF in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 03-06-2013, 10:01 AM
  3. How does Start/Stop interplay with Stop-Go on the ACC?
    By Timothy Nathan in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-02-2012, 11:40 AM
  4. start - stop (or rather not)
    By ti rich in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-02-2012, 10:28 PM
  5. Question Intermittent Stop/Start fault - the saga continues
    By TeaTimeGilly in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-11-2008, 04:32 PM
