Thread: Passat overheating at speed
Results 1 to 8 of 8
  1. Passat overheating at speed
    Nov 2013
    london uk
    Hi, so my i'm on the motorway an driving at 70mph and everything is fine, but if i am doing 80mph after a while the car overheats, the car seems to be creating pressure at speed, but is fine afterwards as long as I dont do over 70mph, PLEASE HELPShift+R improves the quality of this image. Shift+A improves the quality of all images on this page.
  2. Re: Passat overheating at speed
    Nov 2008
    Beverley East Yorkshire
    How's your radiator looking? Not blocked dirty or missing lots of fin's?
    Unauthorised commercial link removed as per forum rules
  3. Re: Passat overheating at speed
    Southern County Softy
    20 Post(s)
    Broken water pump.
    Sent from my GT-I9305 using Tapatalk
    A4 2.5 tdi QS (mapped)
  4. Re: Passat overheating at speed
    Nov 2013
    london uk
    rad looks fine no leaks
  5. Re: Passat overheating at speed
    Nov 2013
    london uk
    would that cause loss of water and no sign of it anywhere?
  6. Re: Passat overheating at speed
    Nov 2008
    No, if your loosing water too with no signs of leaking I would be checking the head gasket water pump could also be leaking!
    How much water has it lost over how long? Is there any mayonnaise under oil filler cap?
  7. Re: Passat overheating at speed
    20 Post(s)
    Are you topping up the coolant on a regular basis ? Water pump vanes break up, this makes them less efficient as pumping the coolant round. This normally shows up at higher speeds as yours does. The cooling system is able to cope at lower speeds due to the rad doing its job.
  8. Re: Passat overheating at speed
    134 Post(s)
    2025 Post(s)
    Classic PD 8 valve head gasket failure symptom.
  1. Please Help Speed related overheating - why?
    By Mikeybs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-09-2012, 10:48 AM
  2. Passat 96, TD Umwelt overheating
    By the_old_diver in forum Early Passat Forum - Pre 97
    Last Post: 27-04-2009, 08:51 PM
  3. 04` Passat TDi overheating
    By duds100 in forum Chat - Anything with wheels
    Last Post: 27-11-2008, 12:52 PM
  4. another overheating passat
    By sparky79 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-06-2008, 04:08 PM
  5. 2001 Tdi130 Overheating @ Higher Speed
    By oxoboy in forum Passat - Archive Topics
    Last Post: 01-01-2008, 10:04 PM
