Thread: A4 1.8t B6- Blue smoke after oil change.
Results 11 to 20 of 34
  1. Re: A4 1.8t B6- Blue smoke after oil change.
    Feb 2010
    uk
    Just before I was going to drain some oil out, I had a 100 mile motorway trip to do. Having returned the oil level has reduced down to the maximum (ie the ridged area just above the hashed area).
    There is an improvement- less smoke.
    It hasn't totally cleared, so of not doesn't go entirely back to how it was before the oil change, I will take the MAF route.
  2. Re: A4 1.8t B6- Blue smoke after oil change.
    Dec 2009
    southampton uk
    Obviously its burning a little oil
    1 1 0
  3. Re: A4 1.8t B6- Blue smoke after oil change.
    Feb 2010
    uk
    I had a look in the manual and it says up to 0.5litres per 1000km is normal- I suppose I now need to monitor to see how much oil.
    Still, I can live with topping the oil up once I a while, just hoping its standard burn assoc with this engine and not something major
    If we go back to the origin of the problem and the (now proven correct) theory that there was probably an additive in the oil, are these additives recommended?
    If so , which one.
    I hve prev used lucas in my power steering and it has reduced a leak by 90%- I know they make a stop smoke formula too.
  4. Re: A4 1.8t B6- Blue smoke after oil change.
    Aug 2011
    Meath
    I'd strongly advise you to put nothing but the correct grade of oil from a reputable maker like Quantum in your engine. These are prone to sludging and adding things to thicken the oil can only reduce the life of your engine. Take an afternoon and remove the sump and pickup etc and give them a good clean.
  5. Re: A4 1.8t B6- Blue smoke after oil change.
    Dec 2009
    southampton uk
    Using a noticeable amount of oil in 100 mls is not good.The handbook figure is not what I would be happy with.My sons S3 with 120k uses a lot less so does my 2.5tdi and my wifes Bora V5 175k is no worse.You need to monitor this to make sure is not getting worse and sort the pipe out asap.
  6. Re: A4 1.8t B6- Blue smoke after oil change.
    Feb 2010
    uk
    Quote Originally Posted by mikeybutch View Post
    I have had the car checked by a garage. They said no obvious oil leak.
    I got a fair quote for the sump clean and pickup pipe change, but couldn't leave the car for the whole day so have to find another day when i can manage without the car.
    No more smoking(yippee); and not yet needed to top up oil.
    Thr mechanic did say I could also have 3 oil changes done, one every 1000 miles, with engine flush each time and that would be good enough to clear sludge too.
    Any thoughts? Is this method as good as dropping the sump and cleaning out?
  7. Re: A4 1.8t B6- Blue smoke after oil change.
    #17
    Aug 2011
    Meath
    NO it's nonsense It has to be stripped and cleaned
    Quote Originally Posted by CLOUD1 View Post
  8. Re: A4 1.8t B6- Blue smoke after oil change.
    #18
    Dec 2009
    southampton uk
    If you had seen what I did when the S3 sump was dropped you wouldn't listen to this mechanic.How would he know if the sludge had gone unless he then dropped the sump?Just nonsense.
  9. Re: A4 1.8t B6- Blue smoke after oil change.
    #19
    Feb 2010
    uk
    The car is going in tomorrow for the pickup pipe job. I have for some castrol edge 5w30 to go in after.
    Is it ok to use longlife oil (quantum 3 longlife) if intending to do frequent changes (every 5000miles). I assume the long life oil is ok on regular servicing just not the other way around(standard oil for longlife intervals)?
  10. Re: A4 1.8t B6- Blue smoke after oil change.
    #20
    Aug 2011
    Meath
    Quantum 5W30 is fine for fixed service interval and 5k is very good for any engine. Longlife oils can be expensive
  1. Blue smoke
    By krispy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-06-2010, 10:45 PM
  2. 99 1.8t blue smoke
    By sparky79 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-12-2009, 08:47 PM
  3. Blue Oil Smoke - Just serviced. What's Going On?
    By ChillOut in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-05-2009, 08:47 PM
  4. Blue smoke & Oil Comsumption TDi
    By olnmfc in forum Chat - Anything with wheels
    Last Post: 02-02-2008, 12:39 AM
  5. Blue smoke -- Help!
    By mrsheen in forum The Commercial Range
    Last Post: 09-06-2007, 08:14 AM
