Thread: Replacing scored OSR ABS Sensor, should I dismantle hub inspect/dress the reluctor ring
  1. Replacing scored OSR ABS Sensor, should I dismantle hub inspect/dress the reluctor ring
    Nov 2013
    Washington
    Ref: 54 Golf 1.9Tdi SE 77Kw To remedy a G44 fault with OSR ABS Sensor, I removed it, although I destroyed it in the process before I realised it could be tapped out with a drift through the wheel bolt hole. The end of the sensor is radially scored down by1mm at one place. Should I just replace the sensor or should I dismantle the hub and inspect the reluctor ring. I have heard a build up of rust can cause the shredding of the sensor, surely this can be dressed off to prevent damage to the new sensor. I believe I need a M18 spline socket and a wheel puller to do the job. The sensor is £50-60 from the ECP/GFS but there is one on ebay for £11, I have heard of these working for people. Any advice on this job is greatly appreciated.
  2. Re: Replacing scored OSR ABS Sensor, should I dismantle hub inspect/dress the reluctor ring
    133 Post(s)
    1987 Post(s)
    Yes the ring on the back of the wheel bearing corrodes meaning a new wheel bearing, we have to do loads of these on the Golf 5 platform. You do need a hefty M18 to get the bolt out and more so to put a NEW one in, my first one sheared off leaving me in a painful crumpled heap on the floor (stop laughing you ********!) when trying to torque the bolt up to 180Nm plus 180 degrees so I bought a genuine one. The torque figure goes off the scale of my biggest torque wrench which reads to 550Nm!! The bearing slides off, no puller required like on a Golf 4, make sure you get the appropriate 30 or 32-mm bearing.
  1. Replacing a front ABS Sensor Passat B5 (1.9 TDI 130)
    By bora23 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-05-2016, 10:45 PM
  2. Replacing O-Ring for Oil Level/Temp Sensor on 2002 Audi Allroad 2.5 TDI Automatic AKE
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-04-2012, 05:25 PM
  3. ABS Sensor and Hub
    By spottedhaggis in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-10-2011, 06:40 PM
  4. Abs Ring
    By daren01 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-03-2009, 12:19 AM
  5. How To Replacing front right abs sensor
    By 04080281 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-08-2008, 09:35 PM
