Thread: What lowering springs???
  1. What lowering springs???
    Northampton UK
    I'm looking to get some lowering springs for my 97 passat tdi.
    Does anyone have any preferences as to which one to get,
    i have been told GMAX are good value for money and do a good job.
    Nij
  2. Re: What lowering springs???
    134 Post(s)
    2007 Post(s)
    Don't just fit lowering springs as your dampers will be worn and they also need to be shorter to match the lowering springs, both typically around 40-mm. My personal favourite combination is Eibach springs and Weitec shortened dampers. You will also need to fit the VW sports suspension shortened bump stops if your car doesn’t already have them.
  3. Re: What lowering springs???
    shorten the stock bumpstops by the ammount the springs lower the car .
  4. Re: What lowering springs???
    134 Post(s)
    2007 Post(s)
    It is much easier to buy the genuine VAG shortened bump stops for the 1BE specification suspension, £18 each front and £16 each rear.
  5. Re: What lowering springs???
    Mar 2009
    Sorry for hi-jacking but I am a complete non-mechanic and I also want to lower my standard 2001 TDI SE so that I can get some new 18" wheels.
    So far I have deduced that I need:
    Lowering springs (Eibach seem good) @ £160
    Apparently it is also a good idea to get "shortened dampers". How much would a set of these cost?
    Plus I need bump stops at £40 to £60
    If somebody can say how much the dampers would cost then it might be possible to know the cost of the parts. I will also need to get a garage to fit all this and that is another £200
  6. Re: What lowering springs???
    Jun 2006
    UK, Mids
    and four wheel custom laser alignment ~£55
    Audi A8 - 2015 - 3.0TDI
  7. Re: What lowering springs???
    Eibach are made with stock shocks in mind , but only lower 25 to 30 mm ,from what i read here.
  1. Lowering Springs ??
    By craigbeal in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-09-2007, 08:43 AM
  2. lowering springs
    By new to vw in forum Passat - Archive Topics
    Last Post: 31-03-2007, 12:56 AM
  3. Lowering Springs for my 1.9 tdi golf III
    By c2crr in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-03-2007, 12:59 PM
  4. Lowering springs
    By diamondbrit73 in forum 80 - 90
    Last Post: 11-02-2007, 08:37 PM
  5. Gti Lowering Springs
    By victorwhiskey in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-09-2006, 06:25 PM
