Thread: Ignition Power Source ?
Results 11 to 20 of 22
  1. Re: Ignition Power Source ?
    46 Post(s)
    Join from fuse tap loom to 12v socket loom
    Blackvue power socket into 12v cig
    Everything plugged in and tucked away
    Wire going to camera in-behind a-pillar (behind the curtain airbag)
  2. Re: Ignition Power Source ?
    Jan 2011
    Stafford, UK
    I assume that this is ignition powered camera.
    Where do you power up from for parking use ?
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  3. Re: Ignition Power Source ?
    46 Post(s)
    Well yes because its running off a ignition fuse?
    I don't use the parking mode as the car just sits in work all day mostly.
  4. Re: Ignition Power Source ?
    Jan 2011
    Stafford, UK
    I want my cake & eat it. I can't see any other way to run both power sources other than the way in my first diagram.
    I have to do this front and rear for the two cameras so that I can have either camera running, depending on how I am parked.
  5. Re: Ignition Power Source ?
    46 Post(s)
    Quote Originally Posted by royclark View Post
    You could buy two of these BlackVue - Power Magic Pro for BlackVue In Car Cameras | eBay
    But there are reports that they're not very good as if the battery reaches the specified cut off point, the camera automatically won't come back on once the car is started.
    If you're worried about parking, just park in the corner of the car park and take up 4 spaces like I do the odd time
    I suggest looking on a electronics forum if you're looking to go further than the fuse-taps.
  6. Re: Ignition Power Source ?
    Jan 2011
    Stafford, UK
    I always do Chris , the wife, who is disabled, always goes on at me for parking miles away from the disabled bays.
    Looked at these Chris, not too keen on them as I will only be parked up for about 1 hour.
    I have been looking on this site for ideas. - Search Results for Query: blackvue | DashCamTalk
  7. Re: Ignition Power Source ?
    #17
    Jan 2011
    Stafford, UK
    Are all of the fuses in the red square ignition live ?
  8. Re: Ignition Power Source ?
    #18
    46 Post(s)
    no idea, i just used an un-used slot and by chance it was switched.
    use your rear wiper fuse, seems the obvious thing to do like I did with my a3.
  9. Re: Ignition Power Source ?
    #19
    Jan 2011
    Stafford, UK
    both but the one you'll most likely to be using (ie rear wiper) are full size fuses.
    The fuse that you have used Chris is free on my fuse board. I have tested it and it is ignition controled.
    I am now going to wire the front Blackvue direct to this fuse as I always park front in to protect the grill, but I am going with the set-up below for the rear so that I have the option of ignition or constant live for parking.
    What I want to know is :- What size fuse do I fit to protect/operate one Blackvue (3.3w max consumption) and to trigger the relay (40A 12v DC) for the rear set-up ?.
  10. Re: Ignition Power Source ?
    #20
    46 Post(s)
    ill check in the morning.
  1. "remove key and ignition still on" - J519 defective be the source?
    By Dpanic in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-01-2013, 04:04 PM
  2. Ignition on power source?
    By fysmd in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-10-2012, 03:36 PM
  3. New DRLs to fit, advise on best power source
    By jimfitton in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-07-2012, 09:35 PM
  4. 12v power source
    By TFSIer in forum Audi A3 - Archive Topics
    Last Post: 17-06-2008, 10:22 AM
  5. Power source for Satnav / Phone Power
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 07-02-2007, 12:43 PM
