Thread: Sump plug torque setting
Results 1 to 9 of 9
  1. Sump plug torque setting
    Nov 2012
    North Somerset
    Can anyone help with the torque setting for the sump plug on the 2.0TDI 55rg also the filter housing. Although I think it's stamped on there, car not here so can't check.
    While I'm at it I've search for torque settings but can't find anything has anyone got a link to such info for all or most of the common torque settings likely to be needed
    cheers
    A6 C6 Avant TDI, de-Badged, LED side lights, LED numberplate lights not just bulbs! so far!!
  2. Re: Sump plug torque setting
    46 Post(s)
    Workshop guide is saying 30nm for "oil drain plug"
    will check filter housing now.
    2 0 0
  3. Re: Sump plug torque setting
    46 Post(s)
    Does
    Oil filter bracket to cylinder block 14nm + 90° turn
    make any sense? let me know if I need to look again
  4. Re: Sump plug torque setting
    Nov 2012
    North Somerset
    Does
    I think so I've a feeling it's stamped on the top of the housing
  5. Re: Sump plug torque setting
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    It is usually stamped on. 25Nm if i remember.
    Alan.
    VW T6 150 DSG Camper £££
  6. Re: Sump plug torque setting
    Pembrokeshire
    22 Post(s)
    the big plastic top thing with the filter inside ?
    thats only 25nm . the seal does the sealing, that cap just holds everything in place.
    3 0 0
  7. Re: Sump plug torque setting
    Jan 2011
    Stafford, UK
    Oil filters are usually hand tight, but I suppose that depends on the size of your gripper.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  8. Re: Sump plug torque setting
    Pembrokeshire
    22 Post(s)
    i am talking about a paper element oil filter with a plastic top rather than a metal cannister oil filter, which is indeed hand tight.
    3 1 0
  9. Re: Sump plug torque setting
    Nov 2012
    Somerset UK
    ^^^ I just make a note of the orientation of the arrow/triangle on the filter housing and retighten to the same position, never a problem and have done 4 times. With the sump it was supposedly 19nm on mine but when I tightened to that it still seeped oil slowly and increased couple of nm a time until didn't seep.
    1 1 0
  1. Question Torque Setting
    By A4 Lad in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-10-2011, 12:38 PM
  2. Replies: 2
    Last Post: 10-04-2011, 08:54 PM
  3. Question 1.6 AEE Sump bolt/plug torque
    By SammoVWT in forum Golf MK3 - 1993 - 1999
    Last Post: 08-11-2010, 10:14 AM
  4. sump plug torque settings
    By Will88 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2009, 05:11 PM
  5. Golf Gt tdi (140) Sump plug torque setting.
    By richard_vw in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-08-2007, 10:54 AM
