Thread: 2004 Passat B5 1.9 TDi Supension a bit sloppy
  1. 2004 Passat B5 1.9 TDi Supension a bit sloppy
    Nov 2013
    United Kingdom scotland
    Just purchased a 2004 Passat B5 1.9 TDi Estate. Although shockers do not seem to be leaking and all springs intact, I find it a bit sloppy to drive compared to my Touran 2.0 TDi which is a year older and handles like a wee go-cart in comparison. I was considering changing the suspension but dont have a huge budget. I had seen a full set of coilovers on Ebay for about 180 quid. I have read these can be a little harsh and hard. Any surgestions please??
  2. Re: 2004 Passat B5 1.9 TDi Supension a bit sloppy
    Oct 2005
    A branded kit that includes shocks and springs that was built for that model will far outperform a super-budget coilover kit.
    Koni do some decent all in one kits - I've had mine on for almost 10 years now, no issues at all.
  3. Re: 2004 Passat B5 1.9 TDi Supension a bit sloppy
    Aug 2009
    Dartford, Kent
    My Passat (1.9TDi Saloon with 94K on the clock), also had wander lust. I changed the shocks for Monroe units. Steering and stability immediately improved. Note on the old shocks, although they looked ok, no sign of damage or hydrolic leakage, they were well beyond there service life. One compressed with very little effort, another was very erratic along the compression stroke.
    The rear units are dead simple to change, no springs to compress and no tricky nuts.
    The front units are a mini nightmare, the relationship between the bottom and top of the MacPhearson strut unit being critical. (2 deg tolerance). Go boldly only if you are a skilled DIY'er.
    Back to the point (I though my Passat had wander lust...) Situation dramatically improved when I had the two rear tyres changed.
    Moral of my story being, check all tyres are of same make/compound before blaming the struts. But beware, struts do need inspection/changing at around 60K.
    Last edited by OpenRoad; 23-11-2013 at 08:49 PM. Reason: Tidied up a few errant words.
    Speed Kills, But you will never get to heaven in a rowing boat!
  4. Re: 2004 Passat B5 1.9 TDi Supension a bit sloppy
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Check all the suspension joints for wear. There are a lot on this over complicated set-up, wear in one will cause the steering to be vague.
    Jack up both front wheels & get someone to grasp the steering wheel firmly, then see if you can turn the road wheels left/right.
  5. Re: 2004 Passat B5 1.9 TDi Supension a bit sloppy
    Nov 2013
    Quote Originally Posted by philipharmes View Post
    Thanks for that,Lee
  1. Question Passat B5 Suspension is a bit sloppy
    By bigchap in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-11-2013, 09:26 PM
  2. Octavia TDI 2001 versus Passat Trendline TDI 2004 towbar compatibilty
    By bjp11scot in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 19-10-2013, 12:07 PM
  3. 2004 Golf GT TDi front supension strut.
    By Sly in forum Golf MK5 - 2004 - 2009
    Last Post: 30-04-2013, 10:13 PM
  4. 2004 passat 130 tdi
    By traynor in forum 1.9TDi - Engine
    Last Post: 06-08-2010, 07:06 PM
  5. Passat TDI S - 2004
    By frazz in forum In Car Entertainment
    Last Post: 29-05-2010, 06:19 PM
