Thread: Engine code issue! HELP
Results 1 to 10 of 10
  1. Engine code issue! HELP
    Sep 2013
    Plymouth UK
    Hi guys.
    I'm having slight difficulty. I bought my 2012 B8 A4 Avant 3.0 Tdi V6 4 Months ago from a mean dealer.
    Anyway, the spec wasnt what i wanted, i wanted the 240hp engine which i thought was the only one used in the B8 models - this was advertised as a 201hp and assured it was right! i like the £120 a year tax price, and loved the car so got it.
    Anyway, im looking into a remap and i've come across a few issues.
    Engine code on log book says CLAB ######
    i have an Experian Vin / reg check by the meain dealer, says CLAB ######
    the sticker on the side of my cam cover - CLA ######
    i was under the impresson the CLAB was 201hp and the CLA was 240?
    a friend has VAGCOM can this confirm?
    or am i talking crap and making a mess out of nothing?
    Cheers.
  2. Re: Engine code issue! HELP
    46 Post(s)
    Go by the code on the data sticker in the spare wheel well.
    There will also be a figure in KW in there so use http://www.rapidtables.com/convert/power/kw-to-bhp.htm to convert it to BHP
    Welcome to VWAF
  3. Re: Engine code issue! HELP
    Sep 2013
    Plymouth UK
    There will also be a figure in KW in there so use Kilowatts (kW) to BHP conversion calculator to convert it to BHP
    Welcome to VWAF
    Unless im being stupid, but there is no other sticker in the wheel well just the wheel and battery / cover.
    Is there any engraving on the engine itself, other than the cam cover sticker ?
    Thanks.
  4. Re: Engine code issue! HELP
    46 Post(s)
    Whats your reg number? Sometimes it can be under the spare wheel, take it out.
    The same sticker will also be in the front inside page of the original service book (non duplicate).
    Post it up then once I see it and check it I'll remove it.
  5. Re: Engine code issue! HELP
    Sep 2013
    Plymouth UK
    the sticker in the service book says its a 150KW (201hp) CLAB
    This differs to the one on the engine CLA (240hp?) and thought that the CLAB stopped in 08 anyway?
  6. Re: Engine code issue! HELP
    46 Post(s)
    No idea but the sticker is correct.
    I konw on some other CR engines the last letter, B in your case is left off, usually to show that most other parts of the engine are shared in different variations. The 2.0's are the same, CAHA, CAHB etc.
    The 201 CLAB is a new engine for the B8 and all 09 onwards engines were CR (common rail).
    Make AUDI
    Model-Series B8
    Model A4 AVANT TDI S LINE
    Year 07-03-2012
    Chassis No. xxxxxxx
    Engine No. CLABxxxxxxx
    Fuel Type DIESEL
    Engine Capacity 2967
    Power (KW) 150
    Power (BHP) 201
    Transmission CVT
    No. of Gears 8
    Body Style ESTATE
    Cylinders 6
    Valves 4
    FWD/RWD/4WD FRONT
  7. Re: Engine code issue! HELP
    Sep 2013
    Plymouth UK
    Thanks for your help.
    looks like my remap gains wont be as good as i was hoping for then!
  8. Re: Engine code issue! HELP
    Sep 2008
    Berkshire
    Quote Originally Posted by Tontsy View Post
    I believe that 201 engine was brought in fairly recently to replace the 2.7 litre. Maybe for the facelifted B8?
    The 240/245 version is used in quattro variations.
    A5 (Cabriolet) 2.0 TDI 177PS S-Line - Scuba blue, Technology pack (high), B&O soundsystem, Bluetooth (low), Heated seats, Autoglym life shine.
    1 1 0
  9. Re: Engine code issue! HELP
    46 Post(s)
    Quote Originally Posted by markp306 View Post
    Correct, the 201 3.0 replaced the old 2.7 and came in fwd only.
    240/245 quattro only.
  10. Re: Engine code issue! HELP
    Sep 2013
    Plymouth UK
    Thanks for your Help guys - it all seems to make sense now.
    Now to find out my best route to go down for a map.
  1. Passat TDI (AVB Engine) fault code 19586 issue
    By brathnach in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-07-2013, 12:52 AM
  2. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  3. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
  4. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
  5. `94 1.8 Driver - Fault code/issue ABS engine
    By BugsyMalone666 in forum Golf MK3 - 1993 - 1999
    Last Post: 22-11-2007, 05:18 AM
